π¨ Skimp | 25% Off until March 30 Buy Now
[Layout Tip] - improving workflow
No problem, guys, happy you find it helpful....
what are the little red arrows in the template for and how do you get rid of them? Thanks for the template!
Hi Joel, if you're referring to red arrows around text it will be because I use a custom typeface that you won't have on your computer. What happens if you open a file that contains a typeface you don't have it loads a default which will no doubt have different size, scale, etc properties..
You'll need to select the text where you see a red arrow, go to your text editor and click unbounded....
Whoops, forgot to upload;
Tim's version of utiler's template; 36x24" etc
