    Plug Hole?
    7 Posts 4 Posters 448 Views 4 Watching
    • 3 Offline
      3eighty
      Is there an easier way to plug the hole in the example with out playing triangle stitch?
      Thank You
      • jeff hammondJ Offline
        jeff hammond
        hard to tell exactly what you have there but from where i'm sitting.. window select the hole and delete it..
        .. redraw one of the face's edge if the surface happens to delete as well..
        dotdotdot
          Maybe Add faces by Tig then Clean Up By Thomthom
          (or maybe Clean Up has also something like fill hole)
            I would do what Jeff suggests. No plugins needed. Works on 3D holes, too.
              No plugins needed.
              yes but when you have thousend of holes on different faces ? πŸ˜‰
                The OP didn't say he had thousands of holes on different faces. πŸ˜’
                  Sure πŸ˜„
