Hello all need help
Anybody have any thoughs that what software capable do this form? I'm thinking rhino but does sketchup has this capability?
Thanks all
Make a plain shape it must be a solid then apply TIG's Slicer 5 (see plugin index).
thanks!, im guessing the dynamic form made by subdivide tool? here is my try out using x and y to form the similiar structure.
Thanks all
yf90
Arc circle tangent of SU are sufficient
Slicer by Tig
You have also Extrude Edges By Rail By Lattice by Tig
or Extrude edges by rail by faces by Tig
etc...
Not being familiar with how slicer works I was curious about doing this with solid tools. It worked sort of but SU really can't do justice to what you show there. It took almost an hour to perform the solid subtraction for one of these. But really I'm not sure if SU can do a good job of even the basic nurb-like shapes, and in the end can't handle the polys.
Hi all
Appreciate all the effort! Im having difficulty to create the join of forms such as the structure to structure like the canopy like a fluidity form
Thanks all
yf90
Thanks all
yf90i'm not convinced that what we're seeing in this types of structures are generally 'blob' shaped.. or something which is made strictly via proxy and subdivision..
i thnk a lot of the times, we're looking at mathematically driven forms.. and at the root, have a fairly simple -or- at least understandable and describable shape
so you might want to- at least for a general type of practice- try to draw the shape or part of the shape in a more strict manner than relying solely on sub division.
Thanks Gilles for the file, i just want to ask how do you do the joint of each component intersecting, is there a plugin do that?
Thanks all
yf90 -
You mean Shell? It's Outer shell, tools/outer shell. In free and pro, works only with solids.
Register LoginAdvertisement
