    Hello all need help
    11 Posts 5 Posters 1.6k Views 5 Watching
    • gillesG Offline
      gilles
      Make a plain shape it must be a solid then apply TIG's Slicer 5 (see plugin index).
      • Y Offline
        yf90
        thanks!, im guessing the dynamic form made by subdivide tool? here is my try out using x and y to form the similiar structure.
        Thanks all
        yf90
        Test with slicer x and y
          Arc circle tangent of SU are sufficient πŸ˜„
          Slicer by Tig
            You have also Extrude Edges By Rail By Lattice by Tig
            http://sketchucation.com/forums/download/file.php?id=47633&mode=view/rokbox.jpg
            or Extrude edges by rail by faces by Tig
            http://sketchucation.com/forums/download/file.php?id=42810&mode=view/rokbox.jpg
            etc...
            • pbacotP Offline
              Not being familiar with how slicer works I was curious about doing this with solid tools. It worked sort of but SU really can't do justice to what you show there. It took almost an hour to perform the solid subtraction for one of these. But really I'm not sure if SU can do a good job of even the basic nurb-like shapes, and in the end can't handle the polys.
              • Y Offline
                yf90
                Hi all
                Appreciate all the effort! Im having difficulty to create the join of forms such as the structure to structure like the canopy like a fluidity form
                Thanks all
                yf90
                The form study of the canopy joint of each structure
                • jeff hammondJ Offline
                  Thanks all
                  yf90
                  i'm not convinced that what we're seeing in this types of structures are generally 'blob' shaped.. or something which is made strictly via proxy and subdivision..
                  i thnk a lot of the times, we're looking at mathematically driven forms.. and at the root, have a fairly simple -or- at least understandable and describable shape
                  so you might want to- at least for a general type of practice- try to draw the shape or part of the shape in a more strict manner than relying solely on sub division.
                  • gillesG Offline
                    gilles
                    Have a look at the file.
                    Seville_V6.skp
                    • Y Offline
                      yf90
                      Thanks Gilles for the file, i just want to ask how do you do the joint of each component intersecting, is there a plugin do that?
                      Thanks all
                      yf90
                      • gillesG Offline
                        gilles
                        You mean Shell? It's Outer shell, tools/outer shell. In free and pro, works only with solids.
