    [Plugin] 3D Text Editor
    202 Posts 50 Posters 197.4k Views 49 Watching
      But you still get the warning? Did you use the VirtualStore check utility?
        JuanV.Soler
        now that´s funny , it says :
        so I do have installed the latest version after all
        I have the virtualstore plugin installed in the folder but it does not show in Plugins SketchUp aplication so I cannot run it
          JuanV.Soler
          no more warnings no . I think that the trick was to ignore the first warning after installed
          As I edited my latest post : I have the virtualstore plugin installed in the folder but it does not show in Plugins SketchUp aplication so I cannot run it
            ? Really? No menu under the Plugins menu?
              JuanV.Soler
              no , no menu under the Plugins menu
                what happens if you type this into the ruby console: TT::Plugins::VirtualStore.check_virtualstore
                  JuanV.Soler
                  The **Text Editor**still works with the same workaround of unticking the extrude function to get the heights modified
                    What does TT::Plugins::Editor3dText::PLUGIN_VERSION report.
                    And what version of Internet Explorer do you have installed?
                    (Lots of questions here - but I'm baffled by what is going on here. It should be working... :s )
                      JuanV.Soler
                      it reports :
                      about Internet Explorer :
                      now those are all my credentials 😄
                        Your 3d Text Editor is out of date. It should be 1.1.3 - if you install the version from EW.
                          JuanV.Soler
                          ............finally.............succeeded
                          .......tyuuuu....... 👍
                              matt.gordon320
                              Hi Thomthom, thanks again for an awesome plugin. I have an idea for a feature that some might find useful if they're doing visualization work - vertically stacked text (like the following, perhaps).
                              http://2.bp.blogspot.com/_nswHPYi_dEw/SoWP9m4sr6I/AAAAAAAAH_4/BUtChw6LSK8/s400/P1000262.JPG
                              Any way, just a thought! Thanks for creating so many awesome tools, it's inspiring. I'm slowly learning code, and it's great to see what you've written.
                              Thanks!
                              Matt
                                FWIW, you can already make vertically stacked text. It would be nice to be able to control things like leading and kerning, though.
                                • G Offline
                                  glro
                                  i downloaded and installed you plugin an TT_Lib_v2.8.3.rbz
                                  but then, when sketchup was launched, a message said i have to download TT_Lib2-2.8.0.rbz
                                  so i uninstalled TT_Lib_v2.8.3.rbz and installed TT_Lib2-2.8.0.rbz
                                  and then it worked
                                  you did a great job
                                  you managed to make a multilines editor...
                                  would it be possible to ...? 😛
                                  have the 3d text in a red/blue plan, instead of red/green?
                                  i would like to use your plugin to add comments to a scene, one comment per scene; usually, the camera is oriented so that vertical objects appear vertical
                                  So, it would be easier to read if the text was in the red/blue plan.
                                  • G Offline
                                    glro
                                    and then it worked
                                    you did a great job
                                    no, i just realised that you can change the plan by writing on a face of the model; so to write vertically, you just have to find a vertical face in the model
                                    • tt_suT Offline
                                      tt_su
                                      Whaaat? 😕
                                      You shouldn't need to downgrade. Are you on Windows by any chance?
                                      Maybe you ended up with some files in VirtualStore...
                                      How did you install it?
                                      • G Offline
                                        glro
                                        Whaaat? 😕
                                        windows 7 64 bits
                                        installed using preferences > extensions
                                        downloaded vers 2.8.3 here
                                        http://sketchucation.com/resources/pluginstore?pln=TT_Lib
                                        but it didn't work so i downloaded the previous version using the link that appeared on my screen
                                        but it's OK now;works great
                                        • tt_suT Offline
                                          tt_su
                                          That is strange. I need to look into that.
                                            matt.gordon320
                                            @dave r said:
                                            [attachment=0:38jz7em6]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:38jz7em6]
                                            http://s23.postimg.org/pu5me6ejb/3d_text_editor.jpg
                                            Dave/TT - I'm glad to hear it's already capable, but here's the embarrassing part:I can't figure out how to do it 😳 . I've updated to the most recent version, but maybe I have an older version floating around in Virtual Store or something?
                                            Thanks!
                                            EDIT - Ok I'm stupid. I just realized what you meant @Dave.
                                            http://s24.postimg.org/x152egbj9/I_m_Stupid.jpg
                                            download screenshot
                                            • 6
                                            • 7
                                            • 10
                                            • 11
                                            • 5 / 11
