    No of Plugins V SU Performance
    12 Posts 6 Posters 543 Views 6 Watching
      seasdes
      Lately I have noticed SU8 (Paid) being slower than usual snapping to points. So I have being thinking (dangerous for me).
      Does the number of plugins stored in the Plugins folder affect the performance of Sketchup.
      Walter
      Using Sketchup Pro 2019
      • KrisidiousK Offline
        Krisidious
        It can... How many do you have?
        More to the point are they all up to date and not conflicting with one another? or even obsolete because another plugin has encompassed them?
        By: Kristoff Rand
          seasdes
          There are approx 90 (*.rb) files in my Plugin folder.
          Walter
          • Chris FullmerC Offline
            That's quite a few in my opinion.
            Make sure you have the newest video card drivers for your video card.
            Another thought is it could be an OpenGL setting. Go to preferences and then go to OpenGL. Try changing fastfeedback. Make sure Hardware acceleration is selected as well. See if that helps.
            Chris
            All my Plugins I've written
              seasdes
              Thanks for your help. I reduced the number of files to about 60. I also turned on fast feedback. Hardware acceleration was turned on. SU now seems to run faster.
              Walter
                It's not really about the number of plugins. It depends on what each plugin does.
                V-Ray for SketchUp makes SU slow to start for instance - for that reason I normally keep it disabled and load it only when I need to render.
                  seasdes
                  Ok I will keep that in mind.
                  Walter
                    There is also the issue of the Registry getting filled with invalid toolbar settings. Are you useing Windows?
                      seasdes
                      Yes I am using W7 Home Professional.
                      Walter
                        250 installed witout any problem πŸ˜„
                        • jgbJ Offline
                          jgb
                          And STILL on SU-V6..... Go figure 🀣
                          jgb
                            Krisidious
                            A plugin to count how many plugins you have?
                            By: Kristoff Rand
