    Stop SketchUp from asking to save file before closing?
    7 Posts 5 Posters 504 Views 5 Watching
    • renderizaR Offline
      renderiza
      I am trying to open another file with code and don't want SketchUp to ask if I wan't to save before closing. The following code is what I am using;
      ` file = Sketchup.find_support_file("file.skp" , "Plugins/folder") ;
      Sketchup.open_file file ;`
      Is there a way to make this happen?
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • soloS Offline
        solo
        Why? do you not want to save before closing? why not just click 'no'?
        http://www.solos-art.com
          Get out while you can Pete
          • massimoM Offline
            massimo Moderator
            πŸ˜†
              renderiza
              Hi, currently working on a platformer type game and want to modify the 'KeyScene' plugin that I previously made to work as the menu interface for the game. Here is link to that plugin just in case; http://sketchucation.com/forums/viewtopic.php?t=49027
              Lets say I click start and then select a level I don't want SketchUp to disrupt the flow of the game to open the file that contains that level.
              • Z Offline
                Zollus
                Based on what I found at http://sketchucation.com/forums/viewtopic.php?f=180&t=23321&start=0
                It looks like you could call a file revert via
                Sketchup.send_action(21485)
                But this only seems to work if you were working with an existing file instead of a new file.
                Alternatively, you could do something like performing a save-as to a junk location
                Sketchup.active_model.save("C;/DeleteMe.skp")
                But not ideal if you are working with a larger model that takes a while to save.
                Hope this helps!
                  renderiza
                  Thank you so much...This solved my problem!
                  The one I am using is your second suggestion since the revert method didn't produce what I wanted. The time it takes to save is not much so I am happy.
                  Again thanks!
