    Gradient colors bug?
    9 Posts 3 Posters 1.1k Views 3 Watching
      Don-Quixote
      Hi guys I have a little problem with some files:
      Sometimes my file show its gradient colors and sometimes I can see only a flat/even color;
      Here some images:
      Shadows are off for both files
      Not flat
      Flat
      • massimoM Offline
        massimo Moderator
        Have you already tried to play with shadows settings light&shadow values? Also try to check/uncheck "use sun for shading".
          Don-Quixote
          Yeah but nothing change
          (cmq puoi parlarmi in italiano)
          • massimoM Offline
            massimo Moderator
            Could you please post the problematic model?
            (qui si parla in inglese πŸ˜‰ )
              Don-Quixote
              (chiedo scusa)
              sometimes I don't understand very well the english (that's why)
              But I tryed to play with the shadows many times...
              what's about "Use sun for shading" ???
              • massimoM Offline
                massimo Moderator
                Just try to check and uncheck it and see if something changes.
                  Don-Quixote
                  I can't believe it, it's only this little mark to give all this problem...woooooooow 😳
                  Thanks a lot
                  • massimoM Offline
                    massimo Moderator
                    πŸ‘
                    Ok moved from Sketchup bugs to Sketchup discussions.
                    Prego. πŸ˜„
                    • Chris FullmerC Offline
                      On some models, I like to turn the "Use Sun for Shading" on, and turn the light slider down to like 15% and shadow slider up to 75%. Sometimes I feel like that lightens the entire model up nicely.
                      All my Plugins I've written
