Gradient colors bug?
Hi guys I have a little problem with some files:
Sometimes my file show its gradient colors and sometimes I can see only a flat/even color;
Here some images:Shadows are off for both files
Have you already tried to play with shadows settings light&shadow values? Also try to check/uncheck "use sun for shading".
Yeah but nothing change
(cmq puoi parlarmi in italiano) -
Could you please post the problematic model?
(qui si parla in inglese
)(chiedo scusa)
sometimes I don't understand very well the english (that's why)
But I tryed to play with the shadows many times...
what's about "Use sun for shading" ??? -
Just try to check and uncheck it and see if something changes.
I can't believe it, it's only this little mark to give all this problem...woooooooow
Thanks a lot
Ok moved from Sketchup bugs to Sketchup discussions.
Prego.
On some models, I like to turn the "Use Sun for Shading" on, and turn the light slider down to like 15% and shadow slider up to 75%. Sometimes I feel like that lightens the entire model up nicely.
