    Help Installing Plugins
    4 Posts 2 Posters 217 Views 2 Watching
      sgcrain
      Hi All
      I am trying to install the LibFredo and FredoScale plugins but they do not appear in the plugins drop down menu.
      I've searched the forums and done the following:
      Installed the plugins in the correct spot: see screenshot:
      Checked permissions: see screenshot:
      Checked Sketchup/preferences/extensions: see screenshot:
      I've run out of ideas. Any help is much appreciated! πŸ‘Š
      • massimoM Offline
        massimo Moderator
        It seems that you didn't respect the correct footprint. You have to put those files (see the picture below) directly in the plugins folder.
          sgcrain
          Duh! Thank you! That did the trick. Much appreciated.
          Thanks goodness for screenshots.
          • massimoM Offline
            massimo Moderator
            πŸ‘
