    πŸ›£οΈ Road Profile Builder | Generate roads, curbs and pavements easily Download
    Shape Bender Woes!
    11 Posts 4 Posters 225 Views 4 Watching
      mjb11800
      Hi all,
      Having a problem with shape bender - my attached image is pretty much self explanatory. I've done everything as per the guide, grouped my object, drew a line running down the side (etc..) But I'm getting horrible results like these, what am I doing wrong?!
      Many thanks for any suggestions,
      M
      • sdmitchS Offline
        sdmitch
        Is the line on the red axis the same length as the selected group? Looks like it is much shorter. The length of the 'bent' group is inversely proportional to the length of the line to the width of the group.
        The relationship of the line to the group will be same as the group to the curve so draw the line along an edge of the group or center it underneath the group.
        http://sdmitch.blogspot.com/
          mjb11800
          Hi there, thanks for the post. Just tried using a centre line for the er.. line. Strangley, the preview is ok, the result is not. 😞 Cant for the life of me, work out wtf is going on.
          • TIGT Online
            The line and curve's start-end are transposed, toggle them with the arrow keys...
            Also how big is this object ?
            Very tiny or enormous things can cause issues...
              mjb11800
              πŸ˜„ Its ok, I fixed it - I just re-installed the plug-in and its working fine. Something must've of screwed up somewhere along the line (pun unintended)
              Cheers for the responses guys
              M
              • sdmitchS Offline
                sdmitch
                How did I miss the start-end reversal! That was the problem so not sure how re-installing solved that. All's well that ends well.
                • TIGT Online
                  He probably redrew the line/arc after the reinstall... and by dumb-luck got them in the right orientation, so no toggle start/end was needed and so it worked...
                    mjb11800
                    eh? so how do you make sure they are not reversed? or is that a daft question?
                      mjb11800
                      Ah, the 'up' button. Sorry to be a dimbo - I'm working in the style of Tim layzell at the moment... need lots of curved lines πŸ˜„
                      • Chris FullmerC Offline
                        You can't make sure they are not reversed when you are drawing them. That's why I had to incorporate a manual reversing method with the arrows. I'm sure I could make it guess smarter now that I know a little bit more about ruby, but I have not yet done it. The main idea behind the reversing is that typically you want the two starts to be on the same side and the two ends to be on the other side. I prefer to put the "starts" on the "left" side (when you have the solid green line pointing up on the screen).
                        Good luck with it. Its a great script with a series of, ummm, quirky personality traits πŸ˜„
                        All my Plugins I've written
                          mjb11800
                          Hi Chris! Absolutely no problems with it now, since I've been matching the start/end positions, its working absolutly fine. The plug-in is great and is saving me a whole load of time/calculations... a great bit of work there Chris πŸ˜„ Many thanks for the response - I fear it was my lack of reading on the plug-in that caused the problem in the first place being the impatient person that I am. Deadlines wait for no man (or woman).
                          All the best, Matt.
