    🫛 Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Camera Settings Help
    renderpluginsextensions
    7 Posts 5 Posters 1.3k Views 5 Watching
      reymond
      Hi Vray Cracks
      i`m new in vray for Sketchup....
      I have a project in which the camera settings are given.
      here the camera setting:
      Focal length: 100
      Eye Height: 53cm
      Focus Height: 8cm
      Camera distance: 90cm
      Model: Hasselblad 500 C / M
      can someone tell me how I set it in vray or handle? 😕
      many thanks for your help
      Sketchup & Vray Trainer
        reymond
        no one a good idea??? 😐
        • P Offline
          pierreaudouin
          clic on "get view aspect" in the output tab.
          • V Offline
            valerostudio
            Sounds like you are asking how to match all the settings of this camera exactly in SketchUp. I think there is a reason why no one has responded. You could set the height and distance and focal length in SU, but I am not sure how you would ever match a camera and vantage point exactly. Sounds like a job for Max and Maxwell.
              reymond
              thank you for your answer valerostudio.
              I've tried it with camera tools ........... you are right it goes into maxwell and also in VrayC4D. why I asked whether in vray for sketchup is also possible.
              • andybotA Offline
                andybot
                well, technically, if you know the camera information - lens length, film width, and you can position your camera correctly, it would be possible to replicate any camera. I've tried with matching a simple DSLR, and the results were fairly close. Did you look to see if you can find the relevant camera parameters in the vray camera options?
                  rspierenburg
                  Have you tried the Advanced Camera Plugin.
                  See here
                  It might be of use to you.
                  Rob
