    Latest version for Mac?
    18 Posts 3 Posters 2.4k Views 3 Watching
      slbaumgartner
      What is the current build version for SU 8.0 on Mac? If I check for updates via the "Check Web for Update" item on the SketchUp menu, it tells me there is a newer version available for update. But if I follow that link and install the "update" it is the exact same 8.0.15157 that I had before. Is the update process broken?
      Steve
      [edit: somehow this got posted twice. sorry about that!]
        Aerilius
        The latest installer for OS X should be 8.0.16845.
        Is the one on this site correct? http://www.sketchup.com/gsu8/download.html
          slbaumgartner
          That's where I went, and after install it still says 8.0.15157. It seems to me that the install goes awfully quickly. Could something else going wrong? Is there anywhere that the installer would log errors?
          Steve
            Aerilius
            Did you completely uninstall the previous version?
            (When I messed around with different installs in different locations, I sometimes got a wrong version number, like if it was caused by remainders of another install.)
              slbaumgartner
              No, because it didn't tell me I needed to. I'll try that next.
              [edit: Just now I completely uninstalled SU (so far as I know how - moved the application folder to trash and emptied), then downloaded a fresh image from the Trimble site, and it still says it is 8.0.15157. Is there somewhere else that it could be leaving cruft behind that I need to clean up? I hate it when there is no clear-cut uninstall!]
              Steve
                slbaumgartner
                Steve
                I just used Pacifist to examine the disk image I downloaded from Trimble, and the info.plist in the package says 8.0.15157. This makes me think that the problem isn't on my end!
                Steve
                  driven
                  http://www.sketchup.com/intl/en/download/gsu.html
                  I just pulled one down from here and I get
                  %(#0000FF)[SketchUp 8.0.16845, © 2012 Trimble Navigation Limited]
                  maybe it's where your getting it from
                  john
                    slbaumgartner
                    john
                    I followed that link, downloaded the package (yet again) and inside it the Info.plist still says 8.0.15157. Are you downloading the free or pro? I wonder if just the free is broken?
                    Steve
                      driven
                      I downloaded 'free', knowing that's what you want...
                      and that clipping was from the contents info.plist (via Pasifist)
                      maybe... Clear all SU downloads, I have had issues with it grabbing the previous version to auto open?
                      john
                        driven
                        That was a different link from Aerilius's that I used...
                          slbaumgartner
                          john
                          If by that you mean to Trash them, I did that. This is getting really spooky! Plus, it is also SU itself that proclaims 8.0.15157 after I try to wipe it completely (following the instructions on the Trimble site) and start afresh...
                            slbaumgartner
                            Yep - I followed the link you posted and still got 8.0.15157. How is that possible ❓ ❓ ❓ ❓ ❓
                              slbaumgartner
                              @driven said:
                              won't be here for long
                              john
                              https://dl.dropbox.com/u/25114184/SketchUp%208.0%20Installer.pkg
                              Alas, gone to 404 before I got there, but thanks for the try.
                              As an experiment, I downloaded from the Trimble site using a Windows box (selecting the Mac version of SU, though) and I still got 8.0.15157. I beginning to wonder if there is a network cache server somewhere holding onto an obsolete version?
                              [edit: the second time I tried, your package was there! Thanks! I'll let you know if it works!]
                                driven
                                I can still get the dropbox download??
                                did you try download as, that should bypass any cache
                                  slbaumgartner
                                  john
                                  That package finally worked! Now I'm more convinced than ever that something between me and Trimble is caching an old version. I wiped Safari's cache, so that shouldn't have been it. Something really strange is going on, but now I have 8.0.16845 again. Thanks a ton!
                                    driven
                                    glad to be of service, I'll close those links now...
                                      driven
                                      try a zipped version REMOVED, you can delete this post
                                        driven
                                        john
                                        %(#FF0040)[REMOVED, you can delete this post
                                        and remove them from yours as well...
