    Install plugin - crash - SU not the same
    3 Posts 2 Posters 184 Views 2 Watching
      danna
      Tried installing a trial to BuildEdge plugin. It seemed to install correctly but while using, SU crashed.
      Then reopened SU and the line tool is not working as normal. I can place one or 1st section of a line, then it does not work anymore.
      I looked for a uninstall of the plugin from control panel but did not see it.
      Then I just removed the BuildEdge folder from the plugins folder.
      Reopened SU, the plugin gone but the line tool still not normal.
      Win XP machine
      • TIGT Online
        As well as a folder of files a tool like that will also have one or more files loading from the Plugins folder.
        You need to remove those too 'by hand' - I suspect that a half-baked observer is still getting made and messing things up...
        Incidentally, I didn't know there were trials of the BuildEdge tools for SketchUp - only for Revit πŸ˜•
          danna
          Thanks Tig, had not thought of the App Data folder.
          Uninstalled then reinstalled and back to normal (me thinks)
