    [Plugin] VisTools v1.3.4
    67 Posts 13 Posters 101.4k Views 13 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @anton_s said:
      I examined the Vis Tools.rb and find it strictly licened.
      πŸ˜† The MIT License is very NON-Strict.
      Really there are only 2 requirements: that the copyright notices of the previous authors must stay in the code documentation (you add your own name if you make changes and distribute an edition of your own;) and the original License text (and it's requirements, along with it's 2 restrictions, AND ALL it's privileges,) must be passed on to any future users, or authors.
      Basically.. the "MIT License" is a liberal, socialistic, community property type of license, that is meant to encourage "open source" projects that anyone can use, and improve. Since many people may put their valuable time into the product and do not want some entity "stealing" their work and turning it into a commercial product,... the license has the requirements that the contributor copyright notices and all privileges to use or modify the software, must be passed on.
      @anton_s said:
      How do I get it?
      The license text IS distributed with the plugin in " %(#004080)[**LICENCE.txt**]", ...
      and I also pasted it into the documentation headers of the " %(#004080)[Plugins/load_VisTools.rb]" extension loader and the " %(#004080)[Plugins/IntrepidBear/VisTools/VisTools.rb]" main script file.
      IF you installed the rbz archive, then you have the license files.
      @anton_s said:
      I found a link here, though I'm still not sure.
      That website has nothing to do with THIS VisTools SketchUp plugin nor it's license.
      That website is a form guide that helps you decide what license to use with YOUR OWN projects, that have never before been subject to any "End-User License Agreement" (EULA), "Terms of Service" (TOS) or "Terms of Use".)
      @anton_s said:
      What kind of licence should I get? MIT?
      The license attached to the plugin IS the MIT license.
      The terms of the MIT license (as distributed with the plugin,) along with the Warranty Disclaimer / Limitations on Liabilities, apply to your use of the software as it is now; and grant you privileges (subject to those 2 restrictions,) to modify or extend the software, and distribute your own edition.
      @anton_s said:
      Is it required to pay for the licence?
      No ... but I would not mind donations to help pay for my time, or new features.
      I could have charged a fee for the updates (under the terms of the MIT license,) but chose not to, because I really did not add any new features. I just cleaned up the code mostly, and fixed a few things. The language support files were done by volunteers back when I forked off the edition that was temporarily called "FreezeTools".
      I do not use the VisTools plugin much myself, because I really do not feel it Freezes things the way they are frozen in AutoCAD. But I suppose it is better than nothing.
      Unless I get feedback from users who really like to use the plugin, and likely get some donations to do more work on it,... I probably will not do much more to it, other than fix any glaring bugs, that are easily fixed.
      I'm not here much anymore.
        Anton_S
        Thank Dan, that explains it well.
        πŸ‘
          Dan Rathbun
          @dan rathbun said:
          @__guanjin__:
          The plugin should have just used English ...
          OK I found the error.
          It was me:
          VisTools.rb: line 95
          @@lang == 'en' %(#008000)[# just use English]
          should be making an assignment:
          @@lang **=** 'en' %(#008000)[# just use English]
          😳 'tupid booboo!
          I'll make changes and push an update.
            Dan Rathbun
            ➑ UPDATE v1.3.2
            Pushed update into a forked GitHub online repository at:
            https://github.com/DanRathbun/sketchup-vistools
            πŸ€“
            Feedback via: https://github.com/DanRathbun/sketchup-vistools/issues
              Dan Rathbun
              ➑ UPDATE v1.3.3
              Added Asian language support:
              • Chinese Simplified (zh-CN) language support by Xiao Long (guanjin)
              • Other Asian language support files (preliminary):
              • Chinese Traditional (zh-TW)
              • Japanese (ja)
              • Korean (ko)
              THANK YOU to :
              • Xiao Long (guanjin)
              Chinese Simplified (zh-CN) language file.
              πŸ€“
              • H Offline
                hygicell
                I have installed vistools with ThomThom's install plugin,
                but I get these startup errors:
                Error Loading File load_VisTools.rb
                C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/load_VisTools.rb:4: syntax error, unexpected '<'
                <!DOCTYPE html>
                C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/load_VisTools.rb:5: syntax error, unexpected '<'
                <html>
                C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/load_VisTools.rb:7: syntax error, unexpected '<'
                <meta charset='utf-8'>
                C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/load_VisTools.rb:8: syntax error, unexpected '<'
                <meta http-equiv="X-UA-Compatible" content="IE=edge">
                C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/load_VisTools.rb:8: syntax error, unexpected tIDENTIFIER, expecting $end
                  Dan Rathbun
                  These errors are not caused by VisTools.
                  VisTools has NO html files, and therefor NO <!DOCTYPE> nor <META> tags,... so the errors are caused by ThomThom's installer in some way. (But may be meaningless.)
                  Restart SketchUp... see if VisTools runs normally after a restart.
                  I have never used ThomThom's installer tool,... NOR DID I EVER SAY VisTools was compatible with it!
                  I recommend using the built-in "Install Extension..." button on the Extensions panel of the Preferences dialog (via the Window menu.)
                  • H Offline
                    hygicell
                    sorry to have upset you, I am only asking for help
                    Thomthom's install pugin has always worked fine for me
                    I have restarted Sketchup several times, to no avail
                    I deleted the intrepidBear folder,
                    the errors remained
                    I then reinstalled the plugin through the built-in "Install Extension..." button on the Extensions panel of the Preferences dialog (via the Window menu.)
                    the error messages still remained,
                    I could not find the menu bar, the plugin was not working
                    I deleted the intrepidBear folder again,
                    now the errors still remain
                    is there anything else I shoud delete?
                    might it be that there is a conflict with TIG' s selectionhideshow.rb ?
                    http://sketchucation.com/forums/viewtopic.php?t=19576
                    greetings
                    Frank
                      That's just bizarre. This Vistool is an RBZ, right? The Simple Installer uses the API to install RBZ so it should be the same as Install Extensions from the UI.
                      No idea what produces that.
                      Looks like the content of the .rb file is HTML ... ? :s
                      Tried re-downloading?
                      Have you looked at the content of the .rb file? Can you upload it for inspection?
                        Sorry, I was thinking of the .rb file.
                        • H Offline
                          hygicell
                          here is the .rbz file
                          grts
                          Frank
                          • H Offline
                            hygicell
                            there's more than one inside the folder
                            I guess you mean load_vistools.rb in plugins folder
                            load_VisTools.rb
                              That file looks fine.
                              Can you try without Additional Folders?
                              • H Offline
                                hygicell
                                I don't really understand what you mean
                                  Your errormessage show that you use the plugin Additional Folders by Fredo. http://sketchucation.com/forums/viewtopic.php?t=39073
                                  Can you disable the plugin and see what happens when SketchUp loads the files without Additional Folders?
                                  • H Offline
                                    hygicell
                                    I have searched for the plugin and can't find it anywhere
                                    it appears to be loaded (see attachments)
                                    it is all a big puzzle for me
                                    Frank
                                      Looks like you got some files stuck in Windows' VirtualStore.
                                      Utility for inspecting it:
                                      http://sketchucation.com/forums/viewtopic.php?f=180&t=48399#p434453
                                      • H Offline
                                        hygicell
                                        done!
                                        here are the results,
                                        looks to me as if all or parts of the plugins folder is in virtualstore
                                        even all program files
                                        what should I do?
                                          First of all you should move them into your real Plugins folder and clean up what you might not need. I see two instances of madefaces for instance.
                                          You probably want to change the permissions of the Plugins folder so you have proper access to it from your user account.
                                          • H Offline
                                            hygicell
                                            you've done it !
                                            problem completely solved!
                                            thanks again, Thomthom
                                            Frank
                                            • 2 / 4
