    [Plugin] VisTools v1.3.4
    67 Posts 13 Posters 110.3k Views 13 Watching
    • Dan RathbunD
      Dan Rathbun
      These errors are not caused by VisTools.
      VisTools has NO html files, and therefor NO <!DOCTYPE> nor <META> tags,... so the errors are caused by ThomThom's installer in some way. (But may be meaningless.)
      Restart SketchUp... see if VisTools runs normally after a restart.
      I have never used ThomThom's installer tool,... NOR DID I EVER SAY VisTools was compatible with it!
      I recommend using the built-in "Install Extension..." button on the Extensions panel of the Preferences dialog (via the Window menu.)
      I'm not here much anymore.
      • H
        hygicell
        sorry to have upset you, I am only asking for help
        Thomthom's install pugin has always worked fine for me
        I have restarted Sketchup several times, to no avail
        I deleted the intrepidBear folder,
        the errors remained
        I then reinstalled the plugin through the built-in "Install Extension..." button on the Extensions panel of the Preferences dialog (via the Window menu.)
        the error messages still remained,
        I could not find the menu bar, the plugin was not working
        I deleted the intrepidBear folder again,
        now the errors still remain
        is there anything else I shoud delete?
        might it be that there is a conflict with TIG' s selectionhideshow.rb ?
        http://sketchucation.com/forums/viewtopic.php?t=19576
        greetings
        Frank
          That's just bizarre. This Vistool is an RBZ, right? The Simple Installer uses the API to install RBZ so it should be the same as Install Extensions from the UI.
          No idea what produces that.
          Looks like the content of the .rb file is HTML ... ? :s
          Tried re-downloading?
          Have you looked at the content of the .rb file? Can you upload it for inspection?
            Sorry, I was thinking of the .rb file.
            • H
              hygicell
              here is the .rbz file
              grts
              Frank
              • H
                hygicell
                there's more than one inside the folder
                I guess you mean load_vistools.rb in plugins folder
                load_VisTools.rb
                  That file looks fine.
                  Can you try without Additional Folders?
                  • H
                    hygicell
                    I don't really understand what you mean
                      Your errormessage show that you use the plugin Additional Folders by Fredo. http://sketchucation.com/forums/viewtopic.php?t=39073
                      Can you disable the plugin and see what happens when SketchUp loads the files without Additional Folders?
                      • H
                        hygicell
                        I have searched for the plugin and can't find it anywhere
                        it appears to be loaded (see attachments)
                        it is all a big puzzle for me
                        Frank
                          Looks like you got some files stuck in Windows' VirtualStore.
                          Utility for inspecting it:
                          http://sketchucation.com/forums/viewtopic.php?f=180&t=48399#p434453
                          • H
                            hygicell
                            done!
                            here are the results,
                            looks to me as if all or parts of the plugins folder is in virtualstore
                            even all program files
                            what should I do?
                              First of all you should move them into your real Plugins folder and clean up what you might not need. I see two instances of madefaces for instance.
                              You probably want to change the permissions of the Plugins folder so you have proper access to it from your user account.
                              • H
                                hygicell
                                you've done it !
                                problem completely solved!
                                thanks again, Thomthom
                                Frank
                                  πŸ‘ πŸ‘ πŸ˜„
                                  • H
                                    hygicell
                                    earned yourself a cookie, or better, a small budget for Belgian beer !
                                    Cheers
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Thanx for straightening that out Thomas!
                                        Thanks to jolran for the Swedish language file.
                                        I am not sure SketchUp would ever load it, as SketchUp does not have a Swedish distribution,... However, a user can always manually edit the "load_VisTools.rb" file and hard set @@lang = "sv" if they wish to force SketchUp to use this file.
                                        For now Swedish file is posted in first post, page 1 of this topic, separately from the rbz archive.
                                        (I will include it at the next release revision.)
                                        πŸ’­
                                        • Dan RathbunD
                                          Dan Rathbun
                                          Testing phase over.
                                          Old versions deleted.
                                          • designerbursaD
                                            designerbursa
                                            SketchUp 8 isolate command does not work.
                                            May I have your update.
                                            or Can you recommend a different version for SketchUp 8.
                                            • 2 / 4
