    [Plugin] VisTools v1.3.4
    67 Posts 13 Posters 110.3k Views 13 Watching
      That's just bizarre. This Vistool is an RBZ, right? The Simple Installer uses the API to install RBZ so it should be the same as Install Extensions from the UI.
      No idea what produces that.
      Looks like the content of the .rb file is HTML ... ? :s
      Tried re-downloading?
      Have you looked at the content of the .rb file? Can you upload it for inspection?
        Sorry, I was thinking of the .rb file.
        • H
          hygicell
          here is the .rbz file
          grts
          Frank
          • H
            hygicell
            there's more than one inside the folder
            I guess you mean load_vistools.rb in plugins folder
            load_VisTools.rb
              That file looks fine.
              Can you try without Additional Folders?
              • H
                hygicell
                I don't really understand what you mean
                  Your errormessage show that you use the plugin Additional Folders by Fredo. http://sketchucation.com/forums/viewtopic.php?t=39073
                  Can you disable the plugin and see what happens when SketchUp loads the files without Additional Folders?
                  • H
                    hygicell
                    I have searched for the plugin and can't find it anywhere
                    it appears to be loaded (see attachments)
                    it is all a big puzzle for me
                    Frank
                      Looks like you got some files stuck in Windows' VirtualStore.
                      Utility for inspecting it:
                      http://sketchucation.com/forums/viewtopic.php?f=180&t=48399#p434453
                      • H
                        hygicell
                        done!
                        here are the results,
                        looks to me as if all or parts of the plugins folder is in virtualstore
                        even all program files
                        what should I do?
                          First of all you should move them into your real Plugins folder and clean up what you might not need. I see two instances of madefaces for instance.
                          You probably want to change the permissions of the Plugins folder so you have proper access to it from your user account.
                          • H
                            hygicell
                            you've done it !
                            problem completely solved!
                            thanks again, Thomthom
                            Frank
                              • H
                                hygicell
                                earned yourself a cookie, or better, a small budget for Belgian beer !
                                Cheers
                                  • Dan RathbunD
                                    Dan Rathbun
                                    Thanx for straightening that out Thomas!
                                    Thanks to jolran for the Swedish language file.
                                    I am not sure SketchUp would ever load it, as SketchUp does not have a Swedish distribution,... However, a user can always manually edit the "load_VisTools.rb" file and hard set @@lang = "sv" if they wish to force SketchUp to use this file.
                                    For now Swedish file is posted in first post, page 1 of this topic, separately from the rbz archive.
                                    (I will include it at the next release revision.)
                                    I'm not here much anymore.
                                    • Dan RathbunD
                                      Dan Rathbun
                                      Testing phase over.
                                      Old versions deleted.
                                      • designerbursaD
                                        designerbursa
                                        SketchUp 8 isolate command does not work.
                                        May I have your update.
                                        or Can you recommend a different version for SketchUp 8.
                                        • C
                                          cuttingedge
                                          Lost my vistools and could find it... This has been the most used tool in my toolsbars. But for some reason I lost it and could make it appear... Must be some plugins that I installed that caused it to disappear. Tried reinstalling via Pluginstore but still it wont show up.
                                          • Dan RathbunD
                                            Dan Rathbun
                                            Check the "View" menu > "Toolbars" submenu. See if it is listed, and check it if it is unchecked.
                                            • 2 / 4
