    [Plugin] VisTools v1.3.4
    67 Posts 13 Posters 110.3k Views 13 Watching
      Anton_S
      Hey Dan, the script and organization is amazingly profesional. ๐Ÿ˜ฎ Indeed, I need to upergrade my scripting skills now...
      • Dan RathbunD
        Dan Rathbun
        Thank you Anton
        โ—
        I'm not here much anymore.
          Anton_S
          I examined the Vis Tools.rb and find it strictly licened. What bugs me is the whole licence thing: โ“
          1. How do I get it? I found a link here, though I'm still not sure.
          2. What kind of licence should I get? MIT?
          3. Is it required to pay for the licence?
          Sorry if my post is a bit of topic though ๐Ÿ˜ณ
          • Dan RathbunD
            Dan Rathbun
            ๐Ÿ˜† The MIT License is very NON-Strict.
            Really there are only 2 requirements: that the copyright notices of the previous authors must stay in the code documentation (you add your own name if you make changes and distribute an edition of your own;) and the original License text (and it's requirements, along with it's 2 restrictions, AND ALL it's privileges,) must be passed on to any future users, or authors.
            Basically.. the "MIT License" is a liberal, socialistic, community property type of license, that is meant to encourage "open source" projects that anyone can use, and improve. Since many people may put their valuable time into the product and do not want some entity "stealing" their work and turning it into a commercial product,... the license has the requirements that the contributor copyright notices and all privileges to use or modify the software, must be passed on.
            @anton_s said:
            How do I get it?
            The license text IS distributed with the plugin in " %(#004080)[**LICENCE.txt**]", ...
            and I also pasted it into the documentation headers of the " %(#004080)[Plugins/load_VisTools.rb]" extension loader and the " %(#004080)[Plugins/IntrepidBear/VisTools/VisTools.rb]" main script file.
            IF you installed the rbz archive, then you have the license files.
            That website has nothing to do with THIS VisTools SketchUp plugin nor it's license.
            That website is a form guide that helps you decide what license to use with YOUR OWN projects, that have never before been subject to any "End-User License Agreement" (EULA), "Terms of Service" (TOS) or "Terms of Use".)
            The license attached to the plugin IS the MIT license.
            The terms of the MIT license (as distributed with the plugin,) along with the Warranty Disclaimer / Limitations on Liabilities, apply to your use of the software as it is now; and grant you privileges (subject to those 2 restrictions,) to modify or extend the software, and distribute your own edition.
            No ... but I would not mind donations to help pay for my time, or new features.
            I could have charged a fee for the updates (under the terms of the MIT license,) but chose not to, because I really did not add any new features. I just cleaned up the code mostly, and fixed a few things. The language support files were done by volunteers back when I forked off the edition that was temporarily called "FreezeTools".
            I do not use the VisTools plugin much myself, because I really do not feel it Freezes things the way they are frozen in AutoCAD. But I suppose it is better than nothing.
            Unless I get feedback from users who really like to use the plugin, and likely get some donations to do more work on it,... I probably will not do much more to it, other than fix any glaring bugs, that are easily fixed.
              Anton_S
              Thank Dan, that explains it well.
              ๐Ÿ‘
              • Dan RathbunD
                Dan Rathbun
                @dan rathbun said:
                @__guanjin__:
                The plugin should have just used English ...
                OK I found the error.
                It was me:
                VisTools.rb: line 95
                @@lang == 'en' %(#008000)[# just use English]
                should be making an assignment:
                @@lang **=** 'en' %(#008000)[# just use English]
                ๐Ÿ˜ณ 'tupid booboo!
                I'll make changes and push an update.
                • Dan RathbunD
                  Dan Rathbun
                  โžก UPDATE v1.3.2
                  Pushed update into a forked GitHub online repository at:
                  https://github.com/DanRathbun/sketchup-vistools
                  ๐Ÿค“
                  Feedback via: https://github.com/DanRathbun/sketchup-vistools/issues
                  • Dan RathbunD
                    Dan Rathbun
                    โžก UPDATE v1.3.3
                    Added Asian language support:
                    • Chinese Simplified (zh-CN) language support by Xiao Long (guanjin)
                    • Other Asian language support files (preliminary):
                    • Chinese Traditional (zh-TW)
                    • Japanese (ja)
                    • Korean (ko)
                    THANK YOU to :
                    • Xiao Long (guanjin)
                    Chinese Simplified (zh-CN) language file.
                    ๐Ÿค“
                    • H
                      hygicell
                      I have installed vistools with ThomThom's install plugin,
                      but I get these startup errors:
                      Error Loading File load_VisTools.rb
                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/load_VisTools.rb:4: syntax error, unexpected '<'
                      <!DOCTYPE html>
                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/load_VisTools.rb:5: syntax error, unexpected '<'
                      <html>
                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/load_VisTools.rb:7: syntax error, unexpected '<'
                      <meta charset='utf-8'>
                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/load_VisTools.rb:8: syntax error, unexpected '<'
                      <meta http-equiv="X-UA-Compatible" content="IE=edge">
                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/load_VisTools.rb:8: syntax error, unexpected tIDENTIFIER, expecting $end
                      • Dan RathbunD
                        Dan Rathbun
                        These errors are not caused by VisTools.
                        VisTools has NO html files, and therefor NO <!DOCTYPE> nor <META> tags,... so the errors are caused by ThomThom's installer in some way. (But may be meaningless.)
                        Restart SketchUp... see if VisTools runs normally after a restart.
                        I have never used ThomThom's installer tool,... NOR DID I EVER SAY VisTools was compatible with it!
                        I recommend using the built-in "Install Extension..." button on the Extensions panel of the Preferences dialog (via the Window menu.)
                        • H
                          hygicell
                          sorry to have upset you, I am only asking for help
                          Thomthom's install pugin has always worked fine for me
                          I have restarted Sketchup several times, to no avail
                          I deleted the intrepidBear folder,
                          the errors remained
                          I then reinstalled the plugin through the built-in "Install Extension..." button on the Extensions panel of the Preferences dialog (via the Window menu.)
                          the error messages still remained,
                          I could not find the menu bar, the plugin was not working
                          I deleted the intrepidBear folder again,
                          now the errors still remain
                          is there anything else I shoud delete?
                          might it be that there is a conflict with TIG' s selectionhideshow.rb ?
                          http://sketchucation.com/forums/viewtopic.php?t=19576
                          greetings
                          Frank
                            That's just bizarre. This Vistool is an RBZ, right? The Simple Installer uses the API to install RBZ so it should be the same as Install Extensions from the UI.
                            No idea what produces that.
                            Looks like the content of the .rb file is HTML ... ? :s
                            Tried re-downloading?
                            Have you looked at the content of the .rb file? Can you upload it for inspection?
                              Sorry, I was thinking of the .rb file.
                              • H
                                hygicell
                                here is the .rbz file
                                grts
                                Frank
                                • H
                                  hygicell
                                  there's more than one inside the folder
                                  I guess you mean load_vistools.rb in plugins folder
                                  load_VisTools.rb
                                    That file looks fine.
                                    Can you try without Additional Folders?
                                    • H
                                      hygicell
                                      I don't really understand what you mean
                                        Your errormessage show that you use the plugin Additional Folders by Fredo. http://sketchucation.com/forums/viewtopic.php?t=39073
                                        Can you disable the plugin and see what happens when SketchUp loads the files without Additional Folders?
                                        • H
                                          hygicell
                                          I have searched for the plugin and can't find it anywhere
                                          it appears to be loaded (see attachments)
                                          it is all a big puzzle for me
                                          Frank
                                            Looks like you got some files stuck in Windows' VirtualStore.
                                            Utility for inspecting it:
                                            http://sketchucation.com/forums/viewtopic.php?f=180&t=48399#p434453
                                            • 2 / 4
