    Rounded corner plugin - need help
    29 Posts 5 Posters 1.4k Views 5 Watching
      If Sketchup becomes 'unresponsive' ["white-out"] it doesn't mean that it has 'hung'.
      It can simply be processing a lot of data.
      Left alone for a few minutes it might well complete the operation.
      Try it on a very simple object to test it.
      Make a square with 1m sides.
      PushPull it into a cube that is 1m high.
      Select just the cube's top face/edges [double-click].
      Run the Round Corners tool.
      In the controls set the radius to 100mm and the number of sides to 6.
        joe depok
        hellooo .... after such uninstall & install .. finally I can use the round corner success .... I again follow the instruction include the "permission" for the plugin folder. thank you thank youuuu ... but 😞 ....it seems that after I update mysketchup program I found that my cursor is not pointed on the right place... for example I want to point the angle . normally I just point my cursor on it and it will snap on the angle.. but now i have to put my cursor somewhere around it to get the snap .. 😞 oh my god....
          joe depok
          this is the screen shot ....
          I can't do diminution, tape measure, rotate, move, etc etc ... it seems that my cursor and the program is not match ...
            joe depok
            the cursor is not located on the green dot ... it's few inch at the top of the green dot..... 😞 .. and I also can not make the rules ....
              This looks like a Graphics card, OpenGL, fast-feedback etc issue.
              Try adjusting these settings one at a time in the Preferences dialog...
              With the correct settings the cursor should return to 'normal'...
                joe depok
                holaaa...
                I already change the setting in open GL but it won't work....
                even the scrolling is switched ... to zoon in I usually fit with scroll up on my mouse ... now it's scroll down ...
                may be any other suggestion ? ... if I go back using my old version of sketch up pro 8 then the round corner is not working..... 😞 😞 😞
                  Double check your system's mouse settings - these might be wrong ?
                    joe depok
                    i already check my mouse setting and all is OK .. event in the preference i try all items and still the mouse located not on the right position. i also already try to reinstall the sketchup but still the same case....
                    • jeff hammondJ Offline
                      jeff hammond
                      hi joe,
                      it seems you may have a corrupt .plist file.. it's possible that all of the uninstall/reinstalls may be the culprit (the sketchup plist files will not remove themselves upon a typical unistall..) you have to trash them manually.
                      try this:
                      --close sketchup
                      --click on finder in the dock
                      --click the 'go' menu at the top of the screen
                      --hold down the option key
                      --a new menu item named 'library' will appear under the go menu (this is the user library-- click on it)
                      --open the folder named 'preferences'
                      --find the file 'com.google.sketchuppro8' (or whatever version you're using)
                      -- trash the file then launch sketchup
                      edit- please note** trashing the .plist file then restarting sketchup will create a new .plist... however, all settings will be at default so it will appear as if you've launched sketchup for the first time (welcome screen, standard template, etc)
                      dotdotdot
                      • 2 / 2
