    Installing plugins
    3 Posts 3 Posters 232 Views 3 Watching
      jpaulsdesign
      New user to sketchUcation.com
      Im not sure what Im missing, but I can't seem to get a plugin installed.
      Im on a mac running 10.8.2
      Im trying to install LibFredo6 round overs
      Can anyone help with specific directions as to how to install these? Im aware that I will need the LibFredo0 AND the round over plugin but cant get them installed properly.....
      Thanks to anyone who can help πŸ˜„
        Rather than repeat all of the links to the 'how to do it' threads that can be found using the Search tool at SCF... πŸ˜„
        I see you are on v8... πŸ˜„
        Can I suggest you find thomthom's 'Simple Plugin Installer' in the 'Plugins Index' accessed via the 'Resources' menu item above...
        If you download and install that tool, using the very clear instructions shown on the download page, then after a restart of SketchUp you can use that tool from the Plugins menu to install any downloaded tools automatically - be they as RB/RBS files or ZIP/RBZ archived formats.
        On a MAC the only thing you must be aware of is that your Safari browser settings must NOT automatically extract the contents of a ZIP file into a subfolder - this setting is only OK only IF you are up to doing a 'manual install' of the extracted files/subfolders, by then moving them to the correct locations - otherwise the simplified installer route will get bust ! 😲
          This has been covered ad nauseum here. Please take a look at this as well as the Round Corners thread.
