    Extending object
    16 Posts 6 Posters 648 Views 6 Watching
      jasemilly
      I have a rectangle with both ends sloped at angle. I would like to increase the length, but the push pull tool goes pulls in the angle of the slopes and the scale tool alters the slope. How do I lengthen it, I am completly stuck
      thanks
      Jasemilly
        Hi Jasemilly, any chance for at least some images - or preferably the skp file itself? (See the "upload attachment tab under the text area of where you write your posts)
        • G Offline
          g_wilson
          Select the sloped face and edges and use the move tool using arrow keys if desired to lock to XY or Z axes. If it is a single edge of a rectangle - select the edge and use move tool as above.
            And for confort of the bounding box selection if your volume(s) is inclined in the 3D space ๐Ÿ˜‰
            Use Fredo Scale โ˜€
            and useful too for the transformation itself ๐Ÿ˜„
              As Gary said, using the Move tool is a good way to do it. Instead of locking the direction with the cursor keys I prefer to use Shift but both ways work. Shift is a single button that works for any move direction and it is on the left end of the keyboard so I don't have to reach across to to the cursor keys. I didn't lock the move direction in this clip and you can see what happened.
              [flash=400,318:q5f5u9iu]http://blip.tv/play/gYhbg4mFeQA?p=1[/flash:q5f5u9iu]
              If you prefer to use a plugin to do things you can easily do with the native tools, Pilou's suggestion also works. ๐Ÿ˜‰
              • Jean LemireJ Offline
                Jean Lemire
                Hi Jasemilly, hi folks.
                A rectangle is a 2D figure and cannot have slanted ends. A trapeze looks like a rectangle with two slanted sides.
                I assume that you mean a rectangular block.
                If so, see this SU file for ideas.
                Lengthening a rectangular block with slanted faces.skp
                  Jean, is that different than my video shows?
                    You have not on the right a Shift key near the 4 cursor keys? ๐Ÿ˜ฒ
                      Sure. I have a Shift key on the right side of the keyboard, too. But why would I reach across the keyboard with my left hand to hit either the right side Shift key or the cursor keys when I can more easily reach the Shift key on the left? My right hand is on the mouse the whole time.
                      My left index finger mostly hovers over the Shift and Ctrl keys while I'm working in SketchUp because I seem to be using them so frequently. I tend to use my left hand to activate most keyboard shortcuts and have very few that require both hands so my right hand stays on the mouse most of the time.
                      How did you conclude that I didn't have a Shift key on the right? It seems like a big leap to me. ๐Ÿ˜•
                        For use in the same time with the left hand the shift key and the curor keys ๐Ÿ˜„
                        No
                        just
                        in some latops for example, the cursor keys are inside the Numeric keyboard ๐Ÿ˜‰
                          I don't use the cursor keys. There's no need for them as far as I'm concerned. The Shift key works to lock direction no matter what direction, even off axis.
                          No
                          just
                          My laptop, a MacBook Pro has the four cursor keys below the right side Shift key and my main machine, a PC desktop has the standard keyboard arrangement with the cursor keys between the main keypad area and the numeric keypad.
                            Jean Lemire
                            Hi Dave, hi folks.
                            Sorry, I could not see the video because of all the blocking software the company is using to stop people from seing videos, hearing music, etc.
                            I only saw a large white rectangle.
                              Curious normally that is France who is blocked! ๐Ÿ˜ฎ
                              This time I can see all animations โ“
                              And there is no music in these animations so more curious ! ๐Ÿ˜ฒ
                                Pilou, I made my video before 4:00 am this morning. the rest of my family was sleeping so I didn't narrate it. Sorry about that. ๐Ÿ˜’
                                  No problem with no existing music or sound speaker ๐Ÿ˜„
                                  It's just that music can be blocked video for some countries! (copyright etc...
                                  Seems the videos are blocked for Jean! So very curious! ๐Ÿ˜ฒ
                                    Jean Lemire
                                    Hi Pilou, hi folks.
                                    It is only at works that many things are blocked or restricted.
                                    Just ideas.
