    Make solid from entities
    9 Posts 3 Posters 637 Views 3 Watching
    • P
      pedromollansaito
      hi there,
      this is my first interaction here.
      does anybody knows a plug-in that automatically make solids from a cluster of entities? In my case i had made some volumes with Gramble 2 (Chris Fullmer tools) and i want each one to be a group. its something like "make group from faces" but for volumes.
      thanks!
      • thomthomT
        If each cluster represent a volume then you can use "Make Group from Faces". In SketchUp everything is just a set of faces anyway. There isn't anything special about solids - except that each edge connect to two faces.
        • TIGT
          A sample image or SKP would help.
          If there are 'loose' edges or interpenetrating faces etc then you won't ever get a solid because the edge.faces.length==2 rule will be broken...
          If you have a series of intersecting/touching simpler solid groups [say 'boxes'] then you can merge these into one larger more complex solid for using one of the 'solid' tools [Pro only]...
          • P
            pedromollansaito
            hi there,
            some images from the clusters of the entities that i want to make individual groups:
            not selected
            https://dl.dropbox.com/u/62794838/clusters-not-selected.jpg
            selected
            https://dl.dropbox.com/u/62794838/clusters-selected.jpg
            they are all ok to be solids. they were faces that were extruded (i used the gramble 2 plugin to make them - actually, if the gramble 2 could group each extruded object it would be perfect...).
            tomtom, i couldn't find the "Make Group from Faces" here in the plugins index. is it in another website?
            thanks for the help!
            • P
              pedromollansaito
              i'm sorry, the name of the plugin is greeble 2 (not gramble...)
              • TIGT
                So to put it another way...
                You want to make all connected faces into separate groups.
                Face2Group http://sketchucation.com/forums/viewtopic.php?p=281272#p281272
                has options to do this...
                • P
                  pedromollansaito
                  hi TIG, i have face2group. it does a group for each face not a group for each cluster (three clicks selection of entities)
                  • thomthomT
                    Loose Geometry to Groups
                    http://sketchucation.com/forums/viewtopic.php?t=16154
                    • TIGT
                      It has several options ?
                      F2G: by Any Edge: Creates a single group for each face selected
                      F2G: by Hard Edge: Creates a single group for each collection of faces defined by a hard edged outer loop
                      F2G: by Hard + Hard Hidden: Creates a single group for collection of faces defined by either a hard edged outer loop or a hard hidden edged outer loop
