    Curiloft plugin help
    10 Posts 6 Posters 652 Views 6 Watching
    • M
      mwm5053
      I' been trying to model a cap iron for a hand plane and just can;t seem to get the result I want any help would be appreciated not to good curviloft yet
      cap iron.skp
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        Walt, my 102 is still sitting here on my desk and I've been thinking about how to model that cap iron, too. Except for the name on it it is symmetrical laterally. So I would only model half of it. I would leave the D-shaped opening out until after you get the shape made.
        Draw the centerline curve and the edge curve. I think you'll also need some curves from the centerline to the outside edge to get that swollen look.
        Compared to the photo, the cap iron on mine sure needs a good polishing job.
        • GaieusG
          So what is this cap iron, guys (beside the obvious - I can see what it looks like in the picture)
            The cap iron is the shiny domed piece on this block plane. It holds the plane iron (blade) in place.
            • TIGT
              ...and because it's such a small plane that part is made 'rounded', so that it doubles as a comfortable handle or grip when it's being 'pushed' - unlike on a larger plane, which will have separate handles/knobs and a 'flatter' metal-plate which will do the 'holding' of the blade...
                Good addition, TIG. This plane is only about 13 cm long so the dome fits nicely into the palm of the hand and you push it with the heel of your hand.
                • GaieusG
                  Thanks guys. One learns something new every day.
                  • pbacotP
                    Walt,
                    Perhaps my attempt might help if you still need ideas on the curviloft lines that Dave describes (Kudos to Fredo!). I had most luck with the top section. You have to look at your plane and decide what curves will work for you. Mine isn't like any plane in existence I'm sure. I was just winging it. I made surfaces in whatever groups of curves that I could. I spent much time reshaping and scaling after, (and still bumpy 😒 ).Screen shot 2012-11-13 at 9.51.21 AM.png
                    I am happier with the result of Artisan and it was much faster, though I still spent a lot of time shaping after with artisan and vertex tools (all hail Whaat & ThomThom!). With more work on the proxy, it could come out better to start with.Screen shot 2012-11-13 at 1.28.26 AM.png
                    Peter
                    • M
                      mwm5053
                      Thanks Peter I appreciate that I"ll see what I can come up with.
                      2011 iMac
                      V2 Twilight
                      • gillesG
                        gilles
                        You could try Sandbox then Jointpushpull.
