    [Plugin] Material_Maintenance v2.2 - 2013-01-13
    155 Posts 19 Posters 69.6k Views 19 Watching
      @cmd
      If you write this in the Ruby Console ENV['TMPDIR'] + <enter> it gives the path to your 'temp' folder.
      In that folder ought to be a subfolder named 'material_maintenance' and in that the xxx.png material thumbnails and xxx.comp.png component thumbnails ? They might have weird looking 'id' type names...
      The subfolder is emptied when the tool runs, or it's made if it is missing.
      It could be that the files are getting made but some enduring issue in the html/js on MAC is preventing them displaying ??
      Can you confirm if the subfolder/files exist...
        Myhand
        @cmd said:
        Myhand,
        Good stuff! no more errors!
        .... but I am not getting material thumbnails nor am I getting component images to display.
        Is this due to the change for mac?
        I suspect it can be to do with the temp folder location on your MAC. I save the thumbs in a folder I create within the system temp folder. I use a technique (from ThomThom's very good article on materials http://www.thomthom.net/thoughts/2012/03/the-secrets-of-sketchups-materials/)
        to "guess" the temp folder.
        temp_path = File.expand_path( ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'] )
        It might be that this does not work on your system and we might have to add some options to the list.
        driven, did you see the thumbs on your system?
        http://www.keepingmyhandin.com/
          The ENV['TMPDIR'] should work on MAC, with the other two for PCs.
          CMD needs to go look see if the subfolder/thumbnails are getting made...
          If they aren't there's an issue with this bit; if they are the issue is with the html/js end ?
            I have experienced some OSX user that didn't have the environment set up correctly - there was no environment temp variable defined at all. That was a once-time thing though.
              OK ... then
              ENV.sort.each{|e|p e};p
              will list everything available...
              • OxerO Offline
                Oxer
                I have the same problem like cmd, the material thumbnails don't appear, I work on Mac OSX.
                Other question, is it possible translate the plugin to another language?
                Thanks Myhand !!
                http://www.oxervision.blogspot.com/
                  Myhand
                  Can you please follow TIG's instructions below and let us know the results?
                  @tig said:
                  @cmd
                  Can you also please run
                  and attach the console output.
                  • cmdC Offline
                    cmd
                    @myhand said:
                    Myhand & TIG
                    Yes... the folders and image files do exist.
                    CMD
                    • CMD
                    • cmdC Offline
                      cmd
                      • CMD
                        So the folder/subfolder is OK and the images exist.
                        The image naming seems unduly convoluted, as it's adding some special characters etc...
                        Why not use each material.display_name [with some replacement of characters like \ / : * ? " < > | etc] linked to a hash of the display-name containing its 'id' ?
                        The thumbnail-images names match the 'display-names' ?
                          Myhand
                          This is sort of what I have done. i.e.
                          display_name + "_" + object_id + ".png"
                          with invalid windows file name characters replaced with the ¶ character. I know this character caused us problems in the marshaling on OSX, but forgot to remove it here. I will do so in the next patch.
                          I do not think this is the problem though as some of the .png files do not have this character in the name...
                          I will add some trace code (and remove the ¶ character) if you do not mind testing again CMD.
                            Why no just remove the miscreant character OR use an _ ?
                            • OxerO Offline
                              Oxer
                              The same like cmd, the folders and image files do exist.
                                Myhand
                                Three reasons (none valid anymore)
                                • I wanted descriptive file names (help with debugging)
                                • I wanted to be clear which chars I replaced (helped with debugging)
                                • I also have an OCD nerve and in theory by just deleting or replacing with a "ordinary" character could clash two similarly names materials that only differed in special characters (and yes it could still happen if each string have the same number of special characters all in the same positions but different characters or if someone actually used the ¶) but I felt the chances were sufficiently small.
                                I will probably go for using object_id as it will be exact(which I did not know existed when I wrote this part if the code initially).
                                  You could make a ruby hash of each material 'display-name'/'id' [rather than it's Sketchup name which will involve [], <> etc if it has been 'imported' etc; this 'display-name' is used in the dialog, and it is then linked to the material's 'id' in the hash. That 'id' is then used for the temp thumbnail png file-name. They are both already unique.
                                  The same applies to the component-thumbnail etc.
                                  You can then use the linked name/id to find the material/defn / id, to associate the right png with the material/defn etc...
                                    Myhand
                                    Is there a reason I not just use the the material's object_id.to_s() as key and also as thumbnail file name etc. It seems unnecessary to concatenate with display_name and then hash, when object_id should be unique within one session...?
                                      How are you to show the display-name AND its matching thumbnail in the dialog etc ? Unless you have both to refer to ?
                                        Myhand
                                        I pass in both the name(as is without any manipulation), and the object_id to the WebDialog. This also allows me to uniquely identify which materials to change. i.e. I only pass the object_id (key) back to Ruby.
                                          archtrot
                                          Great plugin...I've needed something like this for a long time.
                                          The labels on the UI are getting reduced, regardless of window size.
                                          See attached image. Any idea why this is?
                                          I'm SU8 on Windows 7.
                                            ByKAz
                                            Sorry but it didn't work to me...
                                            Any Update!?!?!
                                            • 6
                                            • 7
                                            • 8
                                            • 5 / 8
