    Ingo Maurer Bulb Table Lamp
    21 Posts 7 Posters 3.8k Views 7 Watching
      Just messing around with CurviLoft and Thea. 40 TR2 passes and some DeNoising with NeatImage. Need to make a more accurate filament and add a chrome portion to the inner bulb.
      http://i.minus.com/iXmcxg9iZ9MPk.png
      http://i.minus.com/im6mydszfBuCi.png
      http://i.minus.com/iZQeSpkpUd80A.png
      • boofredlayB Offline
        boofredlay
        Nice work Rich.
        • massimoM Offline
          massimo Moderator
          +1. πŸ‘
          Have you used thin glass for the diffusor? If so i would try with clear glass (dielectric) maybe with 2% of roughness.
            I used the clear glass not the thin for everything. It could be how I constructed it though.
            Should the outer diffuser be a solid?
            • massimoM Offline
              massimo Moderator
              No, I don't think so. That is for the SSS & medium. Maybe just too thin?
                always the perfectionist. you're welcome to have a pop at it if you want
                • massimoM Offline
                  massimo Moderator
                  πŸ˜†
                  You're so right...
                  Gimme.
                    Now it looks like a fish bowl
                    • massimoM Offline
                      massimo Moderator
                      A very quick try with Thea: 4 passes 20 m, TR2 supersampling=high, no post pro (just a little bit of radial glare 3% in Thea's dark room). Keeping your model untouched with the exception of the chrome portion on the inner bulb. Still thinking that 1mm of thickness for the diffuser is a bit little. Also maybe it worth a try to model the diffuser with variable thickness. πŸ˜„
                        I was trying to figure how to a chrome tip that faded to transparent.
                        Thanks for taking peep
                        • massimoM Offline
                          massimo Moderator
                          Well you're right, didn't tried that.
                          • Bryan KB Offline
                            Excellent!
                            At what step did you use Curviloft?
                            • massimoM Offline
                              massimo Moderator
                              How is the fade? Still needs a bit more cooking of course. πŸ˜„
                                Can you share the material setup. I've a mapped inner bulb but getting the setup on materials is confusing. Did you texture the inner mesh of the smaller bulb and apply a coating?
                                • massimoM Offline
                                  massimo Moderator
                                  I've used a gradient map as a mask. In SU I've textured both faces of the small bulb with it. PM'ed both the textured model and the material. πŸ˜‰
                                  • GarethG Offline
                                    Gareth
                                    it just gets betterer and betterer.....!!!
                                    πŸ‘
                                    • olisheaO Offline
                                      olishea
                                      great work rich! Ingenious with the texture massimo!
                                      oli
                                      • massimoM Offline
                                        massimo Moderator
                                        Since someone asked me, here is how the material is made. Quite simple. Rich modeled the bulb with thickness, so the gradient map is applied on both outer & inner face of the model.
                                        Hope you don't mind for the intrusion Rich. πŸ˜„
                                        SU's view
                                        the gradient map
                                        the material in Thea
                                          πŸ˜‰
                                          http://images1.wikia.nocookie.net/__cb20120210161006/picsou/fr/images/c/c8/Helper-par-Rosa.jpg
                                          • GarethG Offline
                                            Gareth
                                            one day, just maybe, the rest of us will catch up with you guys...!! πŸ˜’
                                            • 1 / 2
