Ingo Maurer Bulb Table Lamp
Well you're right, didn't tried that.
Excellent!
At what step did you use Curviloft?
I was trying to figure how to a chrome tip that faded to transparent.
How is the fade? Still needs a bit more cooking of course.
Can you share the material setup. I've a mapped inner bulb but getting the setup on materials is confusing. Did you texture the inner mesh of the smaller bulb and apply a coating?
I've used a gradient map as a mask. In SU I've textured both faces of the small bulb with it. PM'ed both the textured model and the material.
it just gets betterer and betterer.....!!!
great work rich! Ingenious with the texture massimo!
Since someone asked me, here is how the material is made. Quite simple. Rich modeled the bulb with thickness, so the gradient map is applied on both outer & inner face of the model.
Hope you don't mind for the intrusion Rich.
one day, just maybe, the rest of us will catch up with you guys...!!
very clever indeed, much appreciated posting the material settings
