    Sound Effecs in SketchUp (HELP)
    31 Posts 6 Posters 8.0k Views 6 Watching
    • renderizaR
      renderiza
      This is related to the game I am trying to make but this following problem is so important I felt it needed its own thread. I can’t manage to find a solution for playing multiple sounds inside sketchup at the same time. I have tried;
      UI.play_sound:
      I can’t make more than one sound to play at the same time. Can it be done?
      HTML 5 Audio:
      There is a bug when I try to use this in my web dialog inside sketchup. I am presented with this error when trying to play sound using this javascript code;
      var snd = new Audio("sound.wav");
      snd.play();
      The above code will work in any html outside of sketchup…I don’t know why it doesn’t in the web dialog. This is what the error says;
      “Error: ‘Audio’ is undefined “
      Please I need help because for me it’s vital to play multiple sounds at the same time inside sketchup.
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • Dan RathbunD
        Dan Rathbun
        The UI::WebDialog interface is not yet HTML5 compliant. AFAIK
        (You have not filled out your profile, so without knowing what platform you are on, it would be hard to help further.)
        But... you might try playing the sound file by using:
        UI.openURL('C:/path/to/sounds/sound.wav')
        I'm not here much anymore.
        • D
          driven
          and if it was IE can't play .wav in audio tags....
          Desktop browser audio codec support
          Desktop Browser Version Codec Support
          Internet Explorer 9.0+ MP3, AAC
          Chrome 6.0+ Ogg Vorbis, MP3, WAV†
          Firefox 3.6+ Ogg Vorbis, WAV
          Safari 5.0+ MP3, AAC, WAV
          Opera 10.0+ Ogg Vorbis, WAV
          how bizarre
          john
          • TIGT
            There is also the sound specific UI.play_sound('C:/path/to/sounds/sound.wav') which you could include in a timer or animation 'block' so more than one sound runs concurrently ?
            • thomthomT
              It's more IE not being compliant. IE10 should be though. But in a Webdialog you might need to force it into the correct document mode with a meta tag.
              <meta http-equiv="X-UA-Compatible" content="IE=edge"/>
              And have an HTML5 header.
              • renderizaR
                renderiza
                Tried;
                UI.openURL(‘javascript_with_html5_audio.html')
                With the “UI.openURL” I can activate the HTML5 audio using the javascript code but, this action deselects my UI::WebDialog to open the new "html" and it makes the game unplayable.
                Although with that method all the sounds overlay with each other without any problem. Also since multiple sounds are being called constantly the browser is left with too much opened windows tabs (not good).
                If I then use;
                UI.openURL(‘sound.wav')
                This will also deselect the UI::WebDialog to open the audio player.
                I am trying to figure how to make this work by combining the UI.play_sound with UI.start_timer using this code;
                if (params['z'].to_i < 0 ) then
                UI.start_timer(0, false) { UI.play_sound @ball_sound;}
                end ;
                I have not achieved what I want, which is too concurrently overlay sounds one on top of each other without it clipping the sound. Although being able to delay or repeat the sound is nice.
                The “animation ‘block’ suggestion…I am not sure how to try that at the moment so I will research a little bit more to see if I can figure it out.
                Thanks everyone for reply...I will keep trying to solve this.
                • Dan RathbunD
                  Dan Rathbun
                  The Windows Scripting Host can run Js code natively.
                  (1) Try making your javascript a standalone "rezballiza_sounds.js" file.
                  Then call that .js file with:
                  @sounds_path = "C;/path/to/rezballiza/dir"
                  @sounds_script = File.join(@sounds_path,"rezballiza_sounds.js")
                  UI.openURL(@sounds_script)
                  (2) Use Ruby's execute system command (the backquote method.)
                  either:
                  wscript C:/path/to/rezballiza/dir/rezballiza_sounds.js``
                  or:
                  %x[wscript C:/path/to/rezballiza/dir/rezballiza_sounds.js]
                  (In a system command console, type wscript -? to see a popup with wscript command line parameters.)
                  On Windows.. using a backquoted (**``**) or %x` delimited execute string, currently there is no way to suppress the momentary display of a command console window.
                  • renderizaR
                    renderiza
                    Dan Rathbun… I followed you in step 1 but step 2 has me lost.
                    The following is another of my tests;
                    <head>
                    <bgsound src="#" id="soundeffect" loop=0 autostart="true" />
                    </head>
                    <script>
                    var soundfile="zap1.wav"
                    function playsound(soundfile){
                    if (document.all && document.getElementById){
                    document.getElementById("soundeffect").src=soundfile
                    playsound(soundfile) //to play the sound
                    </script>
                    The result;
                    The sounds work but I get a quick screen freeze every time a sound is played. Maybe 300 KB sound size is too much but not sure. Anyways I will keep trying new stuff untill I stumble with a solution. If anyone is brave enough to give it a shoot please do. The game code is here;
                    https://www.dropbox.com/sh/w9m7du0fnhkgwv0/bIqndmMs1S
                    • Dan RathbunD
                      Dan Rathbun
                      They are NOT sequential steps.
                      They were separate suggested possible solutions.
                      Both are Ruby code examples.
                      The global [`()](http://www.ruby-doc.org/core-1.8.6/Kernel.html#method-i-60) method (name is the backquote character) aka ` %x` delimited string.
                      Using special delimited strings ( which refers to:)
                      • Shell Command.
                      A shell command is a string enclosed in backquotes, or in a general delimited string starting with %x. The value of the string is the standard output of running the command represented by the string under the host operating system's standard shell. The execution also sets the $? variable with the command's exit status.
                      dos-like example:
                      filter = "*.rb" files =dir #{filter} files = %x{dir #{filter}}
                      unix-like example:
                      filter = "*.rb" files =ls #{filter} files = %x{ls #{filter}}
                      • renderizaR
                        renderiza
                        I don’t know if I am doing something wrong but the 1st option opens adobe dreamweaver.
                        Dan Rathbun… As much as I will like to say I understand everything, the reality is that I just started the process of learning programming a few weeks ago but I will do my best. Thanks
                        • Dan RathbunD
                          Dan Rathbun
                          UI.openURL will open the file type with the application that is registered by the system for that file extension.
                          Somehow your system was set to open .js files with Adobe Dreamweaver ?
                          This should not have been done.
                          Start Menu > Default Programs > Associate a filetype or protocol with a program
                          ... wait for the list to load (it takes a few minutes.)
                          Scroll down to .js file, and double click it.
                          It should be set to "Microsoft (R) Windows Based Script Host" (which is wscript.exe)
                          If it is set to Adobe Dreamweaver, you should set it back to the default.
                          • Dan RathbunD
                            Dan Rathbun
                            ..., the reality is that I just started the process of learning programming a few weeks ago ...
                            Get and read this: [doc] Programming Ruby (The "Pick-Axe" Book)
                            ... and the Ruby 1.8.6 Reference Dictionary
                            • TIGT
                              Another common screw-up is that .jar files [executable Java archives] that should auto-run as if they were an .exe file can get 'taken over' by several compression apps, and therefore they 'open' rather than 'run' 😒
                              This can break some of my tools that use these file-types to allow image manipulations 'cross-platform' - e.g. ImageTrimmer... 😒
                              • renderizaR
                                renderiza
                                Here is what appears now;
                                Script: C:\Program Files (x86)\Google SketchUp 8\Plugins\Resballiza\resballiza_sounds.js
                                Line: 1
                                Char: 1
                                Error: Syntax error
                                Code: 800A03EA
                                Source: Microsoft JScript compilation error
                                The Javascript file has this code inside;
                                <script>
                                var snd = new Audio("zap1.wav"); // buffers automatically when created
                                snd.play();
                                </script>
                                Maybe I should have other code for it to work.
                                • tbdT
                                  tbd
                                  wonder if http://plugins.ro/labs/suave.htm still works nowadays. as I moved to OSX, anyone wants to try it out ?
                                  SketchUp Ruby Consultant | Podium 1.x developer
                                  http://plugins.ro
                                  • Dan RathbunD
                                    Dan Rathbun
                                    the <script> and </script> tags are HTML tags only for embedding javascript inline inside HTML files.
                                    There are NOT allowed in separate js files.
                                    • renderizaR
                                      renderiza
                                      Well actually I tried it a couple of days ago and didn't get any sounds.
                                      I knew that... 😳 lol
                                      Now the error says;
                                      Line: 3
                                      Char: 1
                                      Error: 'Audio' is undefined
                                      Code: 800A1391
                                      Source: Microsoft JScript runtime error
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Well you would need require the js file where Audio IS defined, I would imagine.
                                        • TIGT
                                          OR perhaps something like
                                          snd=document.createElement('audio'); snd.setAttribute('src', 'zap1.wav'); snd.play();
                                          • D
                                            driven
                                            When run from Ruby Console the tests in the WebDialog , except the 'IE' BGSOUND tag work on a mac, obviously only single file, as written, and only with plugin for the java ones.
                                            wwhdlg = UI;;WebDialog.new("wot_works_here", true, "wwh", 1200, 641, 50, 50, true);
                                             wwhdlg.set_url "http://www.phon.ucl.ac.uk/home/mark/audio/play.htm"
                                             wwhdlg.show_modal
                                             wwhdlg.navigation_buttons_enabled=true
                                            john
                                            • 1 / 2
