    Sound Effecs in SketchUp (HELP)
    31 Posts 6 Posters 7.4k Views 6 Watching
    • renderizaR Offline
      renderiza
      I don’t know if I am doing something wrong but the 1st option opens adobe dreamweaver.
      Dan Rathbun… As much as I will like to say I understand everything, the reality is that I just started the process of learning programming a few weeks ago but I will do my best. Thanks
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • Dan RathbunD Offline
        Dan Rathbun
        UI.openURL will open the file type with the application that is registered by the system for that file extension.
        Somehow your system was set to open .js files with Adobe Dreamweaver ?
        This should not have been done.
        Start Menu > Default Programs > Associate a filetype or protocol with a program
        ... wait for the list to load (it takes a few minutes.)
        Scroll down to .js file, and double click it.
        It should be set to "Microsoft (R) Windows Based Script Host" (which is wscript.exe)
        If it is set to Adobe Dreamweaver, you should set it back to the default.
        I'm not here much anymore.
          Dan Rathbun
          ..., the reality is that I just started the process of learning programming a few weeks ago ...
          Get and read this: [doc] Programming Ruby (The "Pick-Axe" Book)
          ... and the Ruby 1.8.6 Reference Dictionary
            Another common screw-up is that .jar files [executable Java archives] that should auto-run as if they were an .exe file can get 'taken over' by several compression apps, and therefore they 'open' rather than 'run' 😒
            This can break some of my tools that use these file-types to allow image manipulations 'cross-platform' - e.g. ImageTrimmer... 😒
              renderiza
              Here is what appears now;
              Script: C:\Program Files (x86)\Google SketchUp 8\Plugins\Resballiza\resballiza_sounds.js
              Line: 1
              Char: 1
              Error: Syntax error
              Code: 800A03EA
              Source: Microsoft JScript compilation error
              The Javascript file has this code inside;
              <script>
              var snd = new Audio("zap1.wav"); // buffers automatically when created
              snd.play();
              </script>
              Maybe I should have other code for it to work.
              • tbdT Offline
                tbd
                wonder if http://plugins.ro/labs/suave.htm still works nowadays. as I moved to OSX, anyone wants to try it out ?
                http://plugins.ro
                  Dan Rathbun
                  the <script> and </script> tags are HTML tags only for embedding javascript inline inside HTML files.
                  There are NOT allowed in separate js files.
                    renderiza
                    Well actually I tried it a couple of days ago and didn't get any sounds.
                    I knew that... 😳 lol
                    Now the error says;
                    Line: 3
                    Char: 1
                    Error: 'Audio' is undefined
                    Code: 800A1391
                    Source: Microsoft JScript runtime error
                      Dan Rathbun
                      Well you would need require the js file where Audio IS defined, I would imagine.
                        OR perhaps something like
                        snd=document.createElement('audio'); snd.setAttribute('src', 'zap1.wav'); snd.play();
                          driven
                          When run from Ruby Console the tests in the WebDialog , except the 'IE' BGSOUND tag work on a mac, obviously only single file, as written, and only with plugin for the java ones.
                          wwhdlg = UI;;WebDialog.new("wot_works_here", true, "wwh", 1200, 641, 50, 50, true);
                           wwhdlg.set_url "http://www.phon.ucl.ac.uk/home/mark/audio/play.htm"
                           wwhdlg.show_modal
                           wwhdlg.navigation_buttons_enabled=true
                            renderiza
                            Keep getting errors
                            Error 'document' is undefined
                            ...if I use;
                            var snd=document.createElement('audio');
                            var snd.setAttribute('src', 'zap1.wav');
                            snd.play();
                            it says;
                            Error: Expected ';'
                            >  wwhdlg.show_modal
                            This is a nice way of testing what sounds work in UI::WebDialog
                              Perhaps...
                              var snd=document.createElement('audio'); snd.setAttribute('src', 'zap1.wav'); snd.play();
                                renderiza
                                your code works fine when using the .html extension with
                                <script>
                                snd.play();
                                </script>
                                But... when using .js extension and trying to open it with "Microsoft (R) Windows Based Script Host" using this code it does't work.
                                snd.play();
                                  Dan Rathbun
                                  of course not... %(#8000BF)[document] is the HTML DOM object, only valid in browsers.
                                    Dan Rathbun
                                    In a UI::WebDialog for old pre-HTML5 which is what PC SketchUp currently uses...
                                    try using an %(#8000BF)[<embed>] tag.
                                    <EMBED type="audio/x-midi" src="BackInTheSaddle.mid" hidden="true">
                                    see [MSDN: <embed>](http://msdn.microsoft.com/en-us/library/ms535245(v)
                                    And for the various MIME type strings:
                                    Media type - Wikipedia
                                    (en.wikipedia.org)
                                      Dan Rathbun
                                      On Windows there is also a lightweight player in the same folder as the normal Media Player.
                                      It is named "mplayer2.exe"
                                      Command Line options
                                      Also the switch -min or /min seems to work to minimize the interface.
                                      The path on XP:
                                      %(#804000)[%ProgramFiles%/Windows Media Player/mplayer2]
                                      in Ruby that would be:
                                      player_path = File.join(ENV["ProgramFiles"],"/Windows Media Player/mplayer2")
                                      I thot at one time this also was distro'd as an ActiveX control (.ocx file) that could be embedded in webpages ?? (But that may only be MSIE.)
                                        renderiza
                                        Here is how I implemented the <embed> tag;
                                        <script>
                                         function playSound(soundfile) {
                                         document.getElementById("dummy").innerHTML=
                                         "<embed src=\""+soundfile+"\" hidden=\"true\" autostart=\"true\" loop=\"false\" />";
                                         playSound('zap1.wav') // I then place this to play the sounds
                                        </script>
                                        <body>
                                        <span id="dummy"></span> //This needs to be in there or it won't work
                                        </body>
                                        The results:
                                        This script plays the sound but causes lag in the game and makes it unplayable. The frame rate pauses until the sound is played and then it continues.
                                        This problem didn't happen when using the UI.play_sound or UI.openURL because I asume the UI::WebDialog didn't play any part in handling the sound so it never lagged.
                                        I think the best option would have been UI.play_sound if it never clipped the sound when trying to play more than one sound at a time.
                                        The UI.openURL is the next best thing because it overlays sound perfectly and it doesn't cause lag but the UI::WebDialog loses focus and I can't play the game no more. I even try to put this <BODY ONBLUR="window.focus()"> on the webdialog but it didn't work.
                                          renderiza
                                          Actually, the <embed> method is working great for making a sound if you get hit by a ball or if you grab a live or bonus because I don’t mind the pause to the game in that instance…I actually like it!
                                          The only problem left to resolve is how to produce a sound every time a ball falls without clipping the sound and lag.
                                          Well it doesn't work any good now because I added more bonus and lives items and its just a mess when you grab more than one of does.
                                            renderiza
                                            The following solution to be able to play more than one sound simultaneously without sound clipping came to me very randomly. I hope this helps someone and if I ever figure out how to play sounds without small frame freeze then I will post it here. I have gotten less frame freeze using "swf" files but stiil looking to have none slow downs.
                                            <html>
                                             <head>
                                             </head>
                                            <body>
                                             <span id="dummy2"></span>
                                             <span id="dummy3"></span>
                                            </body>
                                            <script>
                                            // Sound Effects
                                             "<embed src=\""+soundfile+"\" hidden=\"true\" autostart=\"true\" loop=\"false\" mastersound />";
                                             function playSound2(soundfile2) {
                                             document.getElementById("dummy2").innerHTML=
                                             "<embed src=\""+soundfile2+"\" hidden=\"true\" autostart=\"true\" loop=\"false\" mastersound />";
                                             function playSound3(soundfile3) {
                                             document.getElementById("dummy3").innerHTML=
                                             "<embed src=\""+soundfile3+"\" hidden=\"true\" autostart=\"true\" loop=\"false\" mastersound />";
                                            // Place Sound effects
                                            playSound('sound_1.swf')
                                            playSound2('sound_2.swf')
                                            playSound3('sound_3.swf')
                                            // ect
                                            </script>
