    Sound Effecs in SketchUp (HELP)
    31 Posts 6 Posters 7.2k Views 6 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      The UI::WebDialog interface is not yet HTML5 compliant. AFAIK
      (You have not filled out your profile, so without knowing what platform you are on, it would be hard to help further.)
      But... you might try playing the sound file by using:
      UI.openURL('C:/path/to/sounds/sound.wav')
      I'm not here much anymore.
        driven
        and if it was IE can't play .wav in audio tags....
        Desktop browser audio codec support
        Desktop Browser Version Codec Support
        Internet Explorer 9.0+ MP3, AAC
        Chrome 6.0+ Ogg Vorbis, MP3, WAV†
        Firefox 3.6+ Ogg Vorbis, WAV
        Safari 5.0+ MP3, AAC, WAV
        Opera 10.0+ Ogg Vorbis, WAV
        how bizarre
          There is also the sound specific UI.play_sound('C:/path/to/sounds/sound.wav') which you could include in a timer or animation 'block' so more than one sound runs concurrently ?
            It's more IE not being compliant. IE10 should be though. But in a Webdialog you might need to force it into the correct document mode with a meta tag.
            <meta http-equiv="X-UA-Compatible" content="IE=edge"/>
            And have an HTML5 header.
            • renderizaR Offline
              renderiza
              Tried;
              UI.openURL(‘javascript_with_html5_audio.html')
              With the “UI.openURL” I can activate the HTML5 audio using the javascript code but, this action deselects my UI::WebDialog to open the new "html" and it makes the game unplayable.
              Although with that method all the sounds overlay with each other without any problem. Also since multiple sounds are being called constantly the browser is left with too much opened windows tabs (not good).
              If I then use;
              UI.openURL(‘sound.wav')
              This will also deselect the UI::WebDialog to open the audio player.
              I am trying to figure how to make this work by combining the UI.play_sound with UI.start_timer using this code;
              if (params['z'].to_i < 0 ) then
              UI.start_timer(0, false) { UI.play_sound @ball_sound;}
              end ;
              I have not achieved what I want, which is too concurrently overlay sounds one on top of each other without it clipping the sound. Although being able to delay or repeat the sound is nice.
              The “animation ‘block’ suggestion…I am not sure how to try that at the moment so I will research a little bit more to see if I can figure it out.
              Thanks everyone for reply...I will keep trying to solve this.
              [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                Dan Rathbun
                The Windows Scripting Host can run Js code natively.
                (1) Try making your javascript a standalone "rezballiza_sounds.js" file.
                Then call that .js file with:
                @sounds_path = "C;/path/to/rezballiza/dir"
                @sounds_script = File.join(@sounds_path,"rezballiza_sounds.js")
                UI.openURL(@sounds_script)
                (2) Use Ruby's execute system command (the backquote method.)
                either:
                wscript C:/path/to/rezballiza/dir/rezballiza_sounds.js``
                or:
                %x[wscript C:/path/to/rezballiza/dir/rezballiza_sounds.js]
                (In a system command console, type wscript -? to see a popup with wscript command line parameters.)
                On Windows.. using a backquoted (**``**) or %x` delimited execute string, currently there is no way to suppress the momentary display of a command console window.
                  renderiza
                  Dan Rathbun… I followed you in step 1 but step 2 has me lost.
                  The following is another of my tests;
                  <head>
                  <bgsound src="#" id="soundeffect" loop=0 autostart="true" />
                  </head>
                  <script>
                  var soundfile="zap1.wav"
                  function playsound(soundfile){
                  if (document.all && document.getElementById){
                  document.getElementById("soundeffect").src=soundfile
                  playsound(soundfile) //to play the sound
                  </script>
                  The result;
                  The sounds work but I get a quick screen freeze every time a sound is played. Maybe 300 KB sound size is too much but not sure. Anyways I will keep trying new stuff untill I stumble with a solution. If anyone is brave enough to give it a shoot please do. The game code is here;
                  Dropbox - No Access - Simplify your life
                  (www.dropbox.com)
                    Dan Rathbun
                    They are NOT sequential steps.
                    They were separate suggested possible solutions.
                    Both are Ruby code examples.
                    The global [`()](http://www.ruby-doc.org/core-1.8.6/Kernel.html#method-i-60) method (name is the backquote character) aka ` %x` delimited string.
                    Using special delimited strings ( which refers to:)
                    • Shell Command.
                    A shell command is a string enclosed in backquotes, or in a general delimited string starting with %x. The value of the string is the standard output of running the command represented by the string under the host operating system's standard shell. The execution also sets the $? variable with the command's exit status.
                    dos-like example:
                    filter = "*.rb" files =dir #{filter} files = %x{dir #{filter}}
                    unix-like example:
                    filter = "*.rb" files =ls #{filter} files = %x{ls #{filter}}
                      renderiza
                      I don’t know if I am doing something wrong but the 1st option opens adobe dreamweaver.
                      Dan Rathbun… As much as I will like to say I understand everything, the reality is that I just started the process of learning programming a few weeks ago but I will do my best. Thanks
                        Dan Rathbun
                        UI.openURL will open the file type with the application that is registered by the system for that file extension.
                        Somehow your system was set to open .js files with Adobe Dreamweaver ?
                        This should not have been done.
                        Start Menu > Default Programs > Associate a filetype or protocol with a program
                        ... wait for the list to load (it takes a few minutes.)
                        Scroll down to .js file, and double click it.
                        It should be set to "Microsoft (R) Windows Based Script Host" (which is wscript.exe)
                        If it is set to Adobe Dreamweaver, you should set it back to the default.
                          Dan Rathbun
                          ..., the reality is that I just started the process of learning programming a few weeks ago ...
                          Get and read this: [doc] Programming Ruby (The "Pick-Axe" Book)
                          ... and the Ruby 1.8.6 Reference Dictionary
                            Another common screw-up is that .jar files [executable Java archives] that should auto-run as if they were an .exe file can get 'taken over' by several compression apps, and therefore they 'open' rather than 'run' 😒
                            This can break some of my tools that use these file-types to allow image manipulations 'cross-platform' - e.g. ImageTrimmer... 😒
                              renderiza
                              Here is what appears now;
                              Script: C:\Program Files (x86)\Google SketchUp 8\Plugins\Resballiza\resballiza_sounds.js
                              Line: 1
                              Char: 1
                              Error: Syntax error
                              Code: 800A03EA
                              Source: Microsoft JScript compilation error
                              The Javascript file has this code inside;
                              <script>
                              var snd = new Audio("zap1.wav"); // buffers automatically when created
                              snd.play();
                              </script>
                              Maybe I should have other code for it to work.
                              • tbdT Offline
                                tbd
                                wonder if http://plugins.ro/labs/suave.htm still works nowadays. as I moved to OSX, anyone wants to try it out ?
                                http://plugins.ro
                                  Dan Rathbun
                                  the <script> and </script> tags are HTML tags only for embedding javascript inline inside HTML files.
                                  There are NOT allowed in separate js files.
                                    renderiza
                                    Well actually I tried it a couple of days ago and didn't get any sounds.
                                    I knew that... 😳 lol
                                    Now the error says;
                                    Line: 3
                                    Char: 1
                                    Error: 'Audio' is undefined
                                    Code: 800A1391
                                    Source: Microsoft JScript runtime error
                                      Dan Rathbun
                                      Well you would need require the js file where Audio IS defined, I would imagine.
                                        OR perhaps something like
                                        snd=document.createElement('audio'); snd.setAttribute('src', 'zap1.wav'); snd.play();
                                          driven
                                          When run from Ruby Console the tests in the WebDialog , except the 'IE' BGSOUND tag work on a mac, obviously only single file, as written, and only with plugin for the java ones.
                                          wwhdlg = UI;;WebDialog.new("wot_works_here", true, "wwh", 1200, 641, 50, 50, true);
                                           wwhdlg.set_url "http://www.phon.ucl.ac.uk/home/mark/audio/play.htm"
                                           wwhdlg.show_modal
                                           wwhdlg.navigation_buttons_enabled=true
                                            renderiza
                                            Keep getting errors
                                            Error 'document' is undefined
                                            ...if I use;
                                            var snd=document.createElement('audio');
                                            var snd.setAttribute('src', 'zap1.wav');
                                            snd.play();
                                            it says;
                                            Error: Expected ';'
                                            >  wwhdlg.show_modal
                                            This is a nice way of testing what sounds work in UI::WebDialog
