    Plugin to cut a building!
    5 Posts 3 Posters 252 Views 3 Watching
    • R
      romulorezende
      I need to make a plan isometric of the ground floor of a building .. I modeled the building, now I wonder if there is a plugin that makes the cutting of walls, windows, doors, components, all at once, and then export the file to cut another program and so do the rendering. As this image link: http://dl.dropbox.com/u/1531688/Isom% C3% A9tricas.jpg
      • R
        romulorezende
        Very nice, but I was thinking in a free Pugin
        • mitcorbM
          mitcorb
          Are you maybe talking about Section Cut Faces? TIG
          • R
            romulorezende
            Yes, but I wanted sliced part of the group was deleted automatically for the plugin .
            • TIGT
              If you want to physically cut the model in half and discard a part of it then you need Zorro2.
              You can use this tool in conjunction with a section-plane and SectionCutFace to split your model in half and add faces to the cuts...
              Search in the Plugins Index for these tools...
              There are several SCF threads discussing how to do this very thing... do a Search...
