Plugin to cut a building!
I need to make a plan isometric of the ground floor of a building .. I modeled the building, now I wonder if there is a plugin that makes the cutting of walls, windows, doors, components, all at once, and then export the file to cut another program and so do the rendering. As this image link: http://dl.dropbox.com/u/1531688/Isom% C3% A9tricas.jpg
Very nice, but I was thinking in a free Pugin
Are you maybe talking about Section Cut Faces? TIG
Yes, but I wanted sliced part of the group was deleted automatically for the plugin .
If you want to physically cut the model in half and discard a part of it then you need Zorro2.
You can use this tool in conjunction with a section-plane and SectionCutFace to split your model in half and add faces to the cuts...
Search in the Plugins Index for these tools...
There are several SCF threads discussing how to do this very thing... do a Search...
