    HDRI for interior?
    renderpluginsextensions
    6 Posts 3 Posters 3.0k Views 3 Watching
    • john2J
      john2
      i've known hdri maps are used for exterior settings as a light source. is hdri used for interiors too? if yes does hdri override the lights used in interiors?
      • andybotA
        andybot
        no, HDRI's typically do not provide enough samples to light an interior.
        • V
          valerostudio
          Unfortunately, we will not be able to do this until the new release with Sky Dome. I think you will be better off using Sky and placing light portals in your openings. The results are great.
          • andybotA
            andybot
            Here is some further discussion about using HDRI for interior - and explains my answer above.
            http://www.chaosgroup.com/forums/vbulletin/showthread.php?69182-HDRI-interior
            (registration required)
            • john2J
              john2
              what is sky portal? and "Sky and placing light portals" is applicable for rendering when daylight is also coming in room with all your lamps and lights on yeah?
              they are not applicable when GI is off and the illumination is completely dependent on interior artificial lights?
              just guessing. πŸ˜‰
              • john2J
                john2
                thank you for this link πŸ˜„
