    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Parklife
    17 Posts 10 Posters 1.1k Views 10 Watching
      davidh
      A few images from a project I have uploaded here before but previously rendered in Vray.Here,again,they are rendered in Thea with no additional photoshop plants but some colour toning done in photoshop.
      • novenaN Offline
        novena
        another fantastic job!!! all your vegetation looks great, wich software do you use??? or is it include in THEA???
        congrats...
        http://hdzarkitektur.wordpress.com/
          davidh
          The trees are birch trees available from the Thea forum for free download to licenced users.The other vegetation is a combination of 3d grass such as from Itoo software that is available to buy on line and ones I have downloaded for free over the last few years.
          (http://archive3d.net is a brilliant resource for free models)
          • novenaN Offline
            novena
            thanks davidh, for your response and the link...
            best
            V
            • Rich O BrienR Online
              What kinda gear do you guys have down there?
              You bang out renders pretty quickly.
              Stunning as always ๐Ÿ‘
              There's a little bit of tiling on the wood but you need to look closely.
              • pbacotP Offline
                David,
                These are spectacular! Do you do this as a business (rendering) or just your own projects? Or just for art's sake?
                Peter
                  jpalm32
                  Really great!
                  I struggle with veg., so I render indoors
                    davidh
                    Most of the images I have uploaded over the last few months have been from jobs we have modeled and uploaded here, in some cases, years ago.
                    Myself and my brother are architectural technicians and the vast majority of of our jobs are technicaly based ,i.e. planning,tender or construction/working drawings,with 3d as a bonus.
                    When we are busy,I always try and find a few hours to "play"- try out different renders.As most of my recent images are based from the interactive mode from Thea,these normally render in the background,and/or overnight.
                    When I actually have a "lunch break"( when you work for yourself,this rarely happens) I always end up in Thea,either trying out a new render,lighting,texture or viewpoint, or checking out how some of the .3ds or .objs that I have downloaded work.
                    • as someone once said - Its not what looks real,its what looks right.
                    Regarding doing these images as a business,I have always found that the clients don't want depth of field/ foreground vegetation/mood,- they all want basic high noon,blue sky,but in my own opinion,the best images we create come from just playing around.
                    (this building/buildings are part of a scheme that I did for my cousin in Watford,UK,just copied and edited as components in sketchup)
                    • hellnbakH Offline
                      hellnbak
                      These are incredible! I really like the depth-of-field effects.
                        davidh
                        3 images done using the relight function in Thea.
                        • hellnbakH Offline
                          hellnbak
                          More fantastic work. Although, in real life that metal bench arm, while beautifully designed, would leave somebody open to all sorts of injury lawsuits. At least in America.
                          • cheddaC Offline
                            chedda
                            Very photographic bravo !
                            Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                            • olisheaO Offline
                              olishea
                              seriously wow!! ๐Ÿ˜ฒ
                              oli
                              • tademaT Offline
                                tadema
                                Beautiful ๐Ÿ˜ฎ
                                John
                                  davidh
                                  This image was rendered overnight but was too grainy so I took the drastic act of blurring the entire image and layering additional planting in photoshop to create a depth of field.(regarding the vegetation,the trees and some of the low planting are rendered,the rest is photoshopped along with the web at the bottom right.)
                                  The original render was way too green at the foreground so I added the coloured flowers and colour toned them so they help to carry the colour of the brickwork forward into the image.Similarly,the pink/purple flowers on the extreme left immediatly behind the foreground plant mirror some of the flower colours in the middle ground of the extreme right.
                                    davidh
                                    Heres the original render (reduced to 1600 for the forum)and a longer uncropped version of the first image.I have added a small texture to the image which helps to reduce the effect of the grain and also helps tie the entire image together.The colours are also more saturated,maybe a bit too much!
                                    • P Offline
                                      pibuz
                                      The colors are just great david!
                                      I think the PS intervention gave the additional touch of life missing in the orginal render.
                                      As always, great work. I'm a big fan of yours ๐Ÿ˜„
                                      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
