    [Resolved] Weird Behaviour
    4 Posts 3 Posters 604 Views 3 Watching
    • MarianM Offline
      Marian
      Here's a weird "bug?" Katalyn27 asked me to post about.
      If you select the first D component and move it about L and A also move without them being in the same group or component, but you can move L and A separately.
      dalina.skp
      • Paul RussamP Offline
        Paul Russam
        That's really odd,
        If you move the D all 3 move
        If you copy the D only it copies
        If you delete the D only it deletes
        Cutting and Pasting in Place the D, L or A fixes it.
        Fix Problems finds no errors and doesn't correct the 'bug'
        Thomthom's cleanup plugin gets rid of some faces materials etc but problem persists.
        Selecting the D and Exploding/Regrouping fixes the 'bug'
        Paul Russam
        English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
          That's because they are glued to the D.
          When you drop an image into a model it will glue itself to the face the move is over when you release the mousebutton. This face can be within a group, component or image. Right click and Unglue to make them independent.
          • MarianM Offline
            Marian
            You are right Thomthom. It did occur to me that it might be glued but when I checked it wasn't glued. I probably right clicked on some other component in there and didn't notice... 😳
