    How to correct view?
    7 Posts 5 Posters 416 Views 5 Watching
    • R
      rumcajs
      I use googlescratchup version 8.
      I have this
      http://i48.tinypic.com/f5ab2f.png
      and want to close look on the wall, but when I get closer, I see nothing or everything disappears. How can I watch the wall closer?
        I can't tell from that image but try setting the Camera to Perspective. Is the model close to the origin? If not, make it so.
        • Dan RathbunD
          Dan Rathbun
          Turn off the Fog if it is on.
          I'm not here much anymore.
          • R
            rumcajs
            That was Perspective. After correction to Parallel Projection was OK. But Now I don't see roof in Parallel View, no fog.
            http://i49.tinypic.com/2qly6vk.png
            • GaieusG
              This is definitely clipping: http://support.google.com/sketchup/bin/answer.py?hl=en&answer=36261
              May I suppose that you are modelling this for Google Earth? If so, another reason can be (apart from what is listed under that link): that you have geolocated your model twice - and one location is quite far away.
              • TIGT
                Have you reset the models axes at all ?
                If so 'reset' them in the context-menu.
                Is ALL of the model's geometry near [within ~200m?] of the model's axes origin ?
                Do you have groups/components that have a sensible insertion point and that are sensibly located in the model, but that contain something far away from their origin - this could perhaps be just a tiny piece of a line - [this is common with CAD imports] - zoom-extents to see if you get unexpected results... or do you have any components that have their contents located sensibly in the model, but that have their origin [insertion-point] miles from its geometry [again common with CAD imports]... You can see components' insertion-point aces using the Model Info toggle...
                A Google-Earth imported mesh might also have similar axes issues ?
                Also... are you sure you are modeling in the correct units - e.g. what you are making is not unexpected gigantic or tiny... for example modeling in mm but thinking it's m [or vice-versa]] might have weird results...
                • R
                  rumcajs
                  It as late night when I had the problem. I saved the project and closed PC. When I started today, so all was right. Except, that when I loaded the file, it looked the same as on the screenshot. But when I moved and zoomed so everything in right in parallel view. I will come back here if I will have some similar issues. Thanks
