    Face selection problem
    9 Posts 4 Posters 473 Views 4 Watching
    • hellnbakH
      hellnbak
      Yeah, I know, another annoying problem from Hellnbak
      When I select individual faces in this area, it's fine
      But when I turn off Hidden Geometry and click within the area, it gives me this
      Normally when this comes up I just select each face within the shape until I find the one causing the problem, but not this time.
      Any ideas?
      • GaieusG
        Any chance for some overlapping faces there? And you know the way to the solution will probably be that you should share at least that part - or (as I see it), sooner or later the whole model even if in parts. πŸ˜„
        • hellnbakH
          hellnbak
          Well, I've gone and done something stupid - I proceeded with what I wanted to do with the model by selecting each face. Thought I had saved it before I did that, but apparently I didn't. Tried undoing it back to original state, but I had done too much and it finally ran out of undo's, and the autosave didn't catch it at the right point.
          My apologies. 😳
          • thomthomT
            I'm going to guess it was a tiny tiny edge there which was soft+smooth that "leaked" the surface.
            • hellnbakH
              hellnbak
              But why wouldn't that show up when I selected each individual face? Guess the point is moot now, I've destroyed the evidence. Really thought I had saved it, and there's very little chance of recreating it. DOH!
              • ToboboT
                Tobobo
                I have this isssue all the time. With the hidden geometry on go and select every face with in the are you want seperate and you will find the 'leak'. For my models it is a pain as they are usually of large landscape projects. when the hidden geometry is on the hidden line complete the face, when it is off the smoothing take over.
                Toby
                Philippians 4:13
                • hellnbakH
                  hellnbak
                  Thanks Toby, but that is exactly what I did (see first two photos). I too have had a "leak" many times, and I've always (until now) been able to easily find it by selecting each face until the leak shows up. That's the whole problem - this time every face selected just fine. But after I turned off the hidden geometry and clicked anywhere within the area, well, you see the results.
                  But I've modified the model and the problem area now no longer exists, so we'll never know for sure what the actual problem was. Can't believe I did that! πŸ˜’
                  • ToboboT
                    Tobobo
                    We all do that. Luckily the IT dept have set up a roll back system on the servers, but doesnt help with the undo issue. Allthough, there is a plugin that expands the number of undos you can have. can't remember what it was called though 😳
                    probably something like 'undo a lot' πŸ˜„
                    Toby
                    Philippians 4:13
                    • ToboboT
                      Tobobo
                      This isn't it but
                      http://forums.sketchucation.com/viewtopic.php?t=46287
                      Toby
                      Philippians 4:13
