    [Plugin] TIG-export_SKP_by_layer.rb
    25 Posts 14 Posters 15.0k Views 14 Watching
      (c) TIG 2012-2017
      Usage: Type into the Ruby Console
      TIG.export_SKP_by_layer
      Exports everything in the current Model into a set of SKP files 'by Layer',
      Faces with Edges on another layer take those Edges with them.
      Potential duplicate layer/skp names are suffixed _1 etc...
      Unused 'empty' layers are ignored.
      The files are named 'modelname-layername.skp'
      Only -a-zA-Z0-9 are used in the file-name, all other characters become ''
      With v2.0 exported SKPs are put into a 'SKP_by_layer' subfolder with the model.
      *With v2.0 you can pass an optional argument to save the SKPs as another version
      e.g. for SketchUp version 8 SKPs pass 8.
      TIG.export_SKP_by_layer(8)
      The version passed must be lower than the Current SketchUp version.
      Allowable versions are: 8, 2013, 2014, 2015, 2016, 2017.
      Note the version passed must be an integer, not a string.
      Passing anything else defaults the SKPs to the Current version.
      Note: with SketchUp < v2014 a different version cannot be specified,
      if one is passed, then it is ignored and it defaults to the Current version.
      You might need to manually delete any unwanted SKB/~.SKP backup files in the
      sub-folder...
      v2.0 20171105
      Now compatible with newer versions of SketchUp.
      Exported SKPs are put into a 'SKP_by_layer' subfolder with the model.
      Optional SKP version argument added to the command*.
      Unused Components, Layers & Materials are properly purged from the SKPs.
      v2.1 20171105
      Layer which exported is not switched ON.
      If the SKP's entities is empty a guide-point is added at the ORIGIN.
      Download the latest version from the PluginStore https://sketchucation.com/pluginstore?pln=TIG_export_SKP_by_layer
      • ToboboT Offline
        Tobobo
        Thanks TIG
        (14 downloads and no comments ๐Ÿ˜’ )
        Toby
        Philippians 4:13
          That's life - ungrateful bunch ! ๐Ÿ˜’
          • gullfoG Offline
            gullfo
            could be we're just a bunch of slackers when it comes to testing and haven't yet checked it out โ˜€
            Glenn
            http://www.runnel.com
            • P Offline
              Phil Rader AIA
              Sounds useful but I don't have a use for it at the moment. Thanks for thinking of useful things even before there is a use for them.
              Regards.
              http://www.philrader.com
              • JClementsJ Offline
                JClements
                I think it will be useful when a model will need to be used by another application .... provided "meaningful" layer naming has been used.
                  Nice one.
                    the.pjt
                    thanks a lot TIG .... thanks ๐Ÿ‘
                    best for exporting to 3Ds max
                    do you have a plan to make it more ? .. a menu .. a toolbar ..
                    do you let me creat a Icon for it ?
                    ๐Ÿ˜›
                    • H Offline
                      hawamazon
                      • halftonejonesH Offline
                        halftonejones
                        Hi TIG,
                        Using this script, can you export SKP layers as .pdf files?
                        Thank you.
                          @halftonejones said:
                          Hi TIG,
                          Thank you.
                          If you want a PDF there's the built in Print to a 2d vector PDF tools, or use a 2d raster PDF system printer like PDF995 ? The built in version only does edges/faces etc and no shadow info is retained.
                          You would need to re-construe the code to get a desired layer/view and then NOT use 'export' but rather 'write_image'.
                          @model.active_view.refresh
                          keys={
                                  ;filename => imgpath,
                                  ;width => vpw,
                                  ;height => vph,
                                  ;antialias => false,
                                  ;compression => 0.9
                          @model.active_view.write_image(keys)
                          This code snippet taken from Slicer5's export_to_png code is for a PNG file, where 'imgpath' tells us where to save it. The equivalent for a PDF would be similar...
                          • Larry BatesL Offline
                            Larry Bates
                            Thanks TIG! layers to 3DS! yes.
                              StephenM
                              TIG,
                              I am having trouble finding out where to locate and how to actually use the plugin...
                              any help would be much appreciated!
                              thank you,
                              Stephen
                                JClements
                                Stephen, does this answer your question?
                                Example 1. The location where the ruby script needs to be copied to.
                                Example 2. How to execute the ruby script (ignore the short-keys for the "Window" menu
                                as these are my custom shortcut key assignments).
                                  I was going to say much the same... but thanks to John !
                                  His explanation is better than mine anyway ๐Ÿ˜’
                                  • O Offline
                                    orthodox32
                                    Thank you TIG! I didn't knew i need this one until i read the description! Life saver, really ๐Ÿ˜„
                                      StephenM
                                      Originally I did that approach and it was not recognizing it... now on a monday morning it works... Figures! haha
                                      The program must have checked out for the week/weekend Friday...
                                      Thank you for the timely response,
                                      Stephen
                                        matt.gordon320
                                        Thanks TIG!
                                        • MrMitchellM Offline
                                          MrMitchell
                                          Tig,
                                          Just a quick question regarding your Layers to SKP plugin:
                                          I have been searching for some ways to get SKP into Revit, and have a couple workflows that I am able to use well currently, however I am trying to just find some quick optimizations and found your old plugin! I am currently using SKP Pro 2015, and just tried your script and this is what the ruby console spat back at me:
                                          Exporting from...
                                          //Mac/Home/Desktop/SKP2RVT/RVT2SKP.skp
                                          as
                                          //Mac/Home/Desktop/SKP2RVT/RVT2SKP-Layer0.skp
                                          Error: #<TypeError: reference to deleted Layers>
                                          C:/Users//AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TIG-export_SKP_by_layer.rb:43:in purge_unused' C:/Users/*****/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TIG-export_SKP_by_layer.rb:43:in block in export_SKP_by_layer'
                                          C:/Users/
                                          /AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TIG-export_SKP_by_layer.rb:40:in each' C:/Users/*****/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TIG-export_SKP_by_layer.rb:40:in export_SKP_by_layer'
                                          <main>:in <main>' SketchUp:1:in eval'
                                          I am using a Mac Laptop with Windows 10 on Parallels if that info helps at all? Anyway, it just creates the first "RVT2SKP-Layer0.skp" file and then stops... I am wondering what is going wrong?
                                          If we can get past this hurdle, one feature I have been looking for in this whole deal is to make sure that whatever files are saved, are saved in SKP8 format ๐Ÿ˜ฎ
                                          Let me know if you can see where I am erring...
                                          Thanks!
                                            Updated v2.0 now available.
                                            See first post full full chanage-log: http://sketchucation.com/forums/viewtopic.php?p=422953#p422953
                                            v2.0 20171105
                                            SketchUp Plugins | PluginStore | SketchUcation
                                            SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                            (sketchucation.com)
                                            • 1 / 2
