    Creating rbz files on Win7
    11 Posts 5 Posters 1.6k Views 5 Watching
    • K Offline
      ktkoh
      Now my windows 7 has started creating compressed folders when I am trying to make a zip file of a plugin and its folders. This compressed folder is not seen by sketchup as a rbz file for installation. In the past my system had been making zip files which I renamed to rbz and this always worked to install as an extension. Is there a setting that will change this problem or do I need a zip program from another vendor??
      Keith
        When you select files and Right Click > Send To > Compressed (Zipped) Folder you don't get a ZIP file?
        That's all what I do - no external applications.
          Aerilius
          Does SketchUp not install it, or does SketchUp install it but not load the plugin (no menu/toolbar etc.)?
          Plugins are only loaded when there is a a *.rb file directly in the Plugins directory. It happened to some people that a zip program put the compressed files into an additional folder inside the zip archive.
            I think he's saying that the folder is compressed - by the filesystem - instead of creating a XIP file.
            http://www.trishtech.com/img_art/winxp_compress_1.jpg
              Are sure you are actually making a ZIP file [NOT a system compressed-file]...
              If so... are your settings to display ALL file-type extensions [Folder-Options].
              If not then xxx [which actually represents xxx.zip] will rename to xxx.rbz which in turn is representing xxx.rbz.zip, which is therefore still a 'zip' file, and therefore it is not listed when using the RBZ archive installer.
              • Dan RathbunD Offline
                Dan Rathbun
                Just get 7zip it's a great free utility.
                I'm not here much anymore.
                • K Offline
                  ktkoh
                  When I right click on a selected file or files in windows explorer the send to option for compress is a zipped folder not a zipped file like it was previously.
                  Dan what option do you use in 7zip I tried that but SU could not install from that file when I renamed it rbz???
                    Aerilius
                    7zip supports a lot of archive formats. What you want for SketchUp is zip (not 7z). The default settings for zip should be ok. Did that work?
                    • K Offline
                      ktkoh
                      Yes 7Zip worked when I selected send to xxxxxxxxxx.zip file. Thanks
                      Still don't understand what happened to my Win7 to make this a problem!!! I assume it came with one of the updates.
                      Keith
                        Hasn't happened on any of my personal computers and none of the computers at the office...
                        • K Offline
                          ktkoh
                          Mistry with win7 zip files solved!!! Some how my folder option to hide known extensions was selected and this created the problem making a ziped file a ziped folder. I know I had nothing to do with that change as it took me a long time to find Folder Options after I started looking for them.
                          Keith
