    Vray problem.
    renderpluginsextensions
    5 Posts 4 Posters 1.0k Views 4 Watching
      Dr Phibes
      Hello all. I'm finding that I get an error when rendering in Vray when I have imported an object in either 3ds or collada format. Stranger still, it only occurs with cubed or rectangular objects. Anyone else had this problem/ know a solution?
      • andybotA Offline
        andybot
        what's the error and what version of vray are you running?
          I echo Andy's request for more info.
          On a general note, I generally model with V-Ray unloaded. And load it only when it comes to the stage I need to render. That way I void many of the potential bugs related to materials.
          • ToboboT Offline
            Tobobo
            Similar to Thom, I model without materials until I'm ready to start rendering and then slowly build up the texture, test rendering as I go.
            Would be good to upload the problem .skp
            Toby
            Philippians 4:13
              I meant that I don't even have V-Ray loaded at all. I find it to add too much too SU startup time - and there are bugs when copying geometry between models when VfSU is loaded.
