    What The Phong!?
    renderpluginsextensions
    7 Posts 5 Posters 2.0k Views 5 Watching
    • V Offline
      valerostudio
      Do any of you guys use the Phong shader? If so, in what cases do you prefer it over Blinn? Ward from what I understand is for metals and should be used lightly because of increased render times, correct?
        I haven't played around with the shaders in V-Ray. When I used 3ds max many years ago I was messing about with it - but I can't remember what I used them for. πŸ˜•
        • V Offline
          valerostudio
          Did some testing using the FormFonts tester ball to compare the 3 shaders and their affect on render time. Phong seems to render faster and blur reflections a bit less. Ward, from what I am told, is good for metals but render times are much longer. Blinn seems to be good for materials where you want really blurry reflections.
          All renders are setup with a fresnel reflection at .85 Glossiness with 12 subdivs.
          Blinn Shader
          Phong Shader
          Ward Shader
          • andybotA Offline
            andybot
            nice πŸ‘ - thanks for the test samples. I guess I've used a shorthand comparison to keep them straight in my head: Phong = plastic; Blinn = wood (lacquered); Ward = metal.
            • holmes1977H Offline
              holmes1977
              Cheers for the tests. Ive only used WARD out of all those shaders.
              Exaggeration makes a dull story better.
              • soloS Offline
                solo
                http://www.microkitten.com/images/c3ru/Brazilian-thong.jpg
                http://www.solos-art.com
                  http://memecrunch.com/meme/7OHX/i-see-what-you-did-there/image.png
