    [REQ] delete coplanar edges with 1 undo
    6 Posts 4 Posters 2.1k Views 4 Watching
    • halroachH Offline
      halroach
      I know there is a delete coplanar context menu plugin. I use it all the time. I have version 1.2 by Jack Dolabany from 2005.
      1. It would be nice to have a single undo for the procedure.
      2. Maybe there are alternative plugins out there?
      3. I can't find the delete coplanar plugin in the list of plugins in the forum... It's worth adding.
      Good Day!
      FlexTools - Super Quick Windows, Doors, Slats...
        CleanUp: http://forums.sketchucation.com/viewtopic.php?t=22920
        • TIGT Online
          To be 'undoable' you simply need a
          Sketchup.active_model.start_operation("DeleteCoplanarEdges")
          before the deletion starts and a
          Sketchup.active_model.commit_operation
          after it's finished - then a single 'undo' undoes all...
          I've PM'd you my own version and another selection utility...
          • halroachH Offline
            halroach
            1. TIG, I think you should publish your two useful plugins.
            2. Thom, I've been using cleanup, but for some reason the remove coplanar doesn't quite give the same results. It doesn't erase all the edges, like with the other script. Just drawing a bunch of intersecting rectangles, pulling a few faces out, and many lines stay...
            Thanks to both of you! Always so quick to reply, with lovely results!
              Ensure that Erase Stray Edges is also enabled.
                the.pjt
                you can use thomthom's clean up http://forums.sketchucation.com/viewtopic.php?t=22920 ...
                thomthom, your cleanup plugin is one of the best and must used tools ... thank you .. thank you a lot ... fot making this graet tool ...
                I can't model any thing without Ctrl+E ( my own shortcut to "clean with last settings" ) and "repair edge"
                wish you the best
