    Help creating a 3D model of a hotwire cut airfoil.
    8 Posts 5 Posters 1.4k Views 5 Watching
    • G Offline
      GreenAce92
      Hello All,
      I developed this aircraft as a proof of concept of an Ultralight that I designed. I wanted to create plans for it so that others may build it as well. I am having troubles figuring out how to create the airfoil you see it isn't simply a "draw airfoil - extrude - scale other end".
      The way this airfoil is produced is by taking two templates, one for the root chord of the wing ( center ) and one for the tip chord of the wing ( wing tips ). Then by use of a hotwire cutter, the airfoil is created by basically tangential cutting, so you see, by using a blend of both a washout of 2 degrees and a 0 degree incidence airfoil, you get a twisting "washout" effect.
      I don't know how to make something like this in sketchup, can someone help me out?
      http://i253.photobucket.com/albums/hh55/GreenAce92/Bobinsky - Stub-wing ultralight/DSC00813.jpg
      Here are the airfoils which I drew myself.
      Regards,
      Jacob Cunningham
      • sdmitchS Offline
        sdmitch
        The main wing can be created in the same manner as I created this tail section.
        [flash=800,600:1wwmb3e1]http://www.youtube.com/v/cpj6GZg_7V0[/flash:1wwmb3e1]
        http://sdmitch.blogspot.com/
        • G Offline
          GreenAce92
          Hello Sam,
          I watched your video. Unfortunately my wing is not as simple as your wing.
          If you imagine the two templates above spaced 18" from each other, then a hot wire traces these two shapes, you can see how this shape is not something that can just be made by "scaling" one side, it is a shape that changes across the entire span of the wing.
          One method I can think of is to cut sections from the wings and then trace those sections, align them and join them with the "draw-sandbox" tool but that defeats the purpose of designing since that would require a product that already exists to be reverse-designed into a CAD model.
          I appreciate the response however.
          Is it not possible to have two different shapes, then some sort of command creates a solid object as if a skin was rolled around these objects? Take an ellipse and a square then create a skin that joins these two shapes into a vase like structure.
          Regards,
          Jacob Cunningham
            Here is a method using only native SU tools (Arc, PushPull and Scale)
            [flash=640,480:1o9428hs]http://www.youtube.com/v/QO_D3ltOilk[/flash:1o9428hs]
              mac1
              AIRFOIL.skpTake a look at Fredos curviloft tool. The attached used your info above, F spline fit to those, set scale of bottom to the 3" ref, did not set 2" of the top, 18 " separation. There are question about the station and position relation. Curves need clean up or provide x.y.z and station info. 😕
              • mitcorbM Offline
                mitcorb
                @Gaieus:
                That video has trouble starting.
                  mac1
                  Did for me also but it did run>
                  • mitcorbM Offline
                    mitcorb
                    Well, it's an oldie but a goodie. I remember it when I hopped on at SU v6.
