    [Plugin] Scale Face to Target Area - TIG
    46 Posts 11 Posters 27.0k Views 11 Watching
    • EarthMoverE Offline
      EarthMover
      Is it possible through ruby (or does something exist) to scale a face to a desired area size? Let's say I draw an irregular shape which needs to be a specific square footage. Is it possible to have a plugin which let you click on the face and set a desired square footage and the face automatically scales to that area?
      I'm drawing a bunch of different free form (lagoon style) pools for a client, but have a target square footage the shapes. I can get close with trial and error and scale tool, just thought it would be nice to do it exact through a script.
      EDIT - Plugin attached. Thanks TIG.
      EDIT: by TIG - code fixed for all unit types !
      TIG Donations==PayPalButton
      Original version
      Alternate version to work with any unit type.
      Content Creator at Skapeup
        <span class="syntaxdefault">module TT_ScaleToArea<br />  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">scale_face</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> face</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> target_area </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    unit_ratio </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">'1'</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_l </span><span class="syntaxkeyword">**</span><span class="syntaxdefault"> 2<br />    target_area_inch </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> target_area </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> unit_ratio<br />    ratio </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> target_area_inch </span><span class="syntaxkeyword">/</span><span class="syntaxdefault"> face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">area<br />    pt </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">bounds</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">center<br />    tr </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">scaling</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> pt</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> ratio </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">parent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transform_entities</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> tr</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  end<br />end<br /></span>
        TT_ScaleToArea.scale_face( Sketchup.active_model.selection[0], 4000 )
        target_area is numeric input in the current model units.
          Here's my version, with dialog...
          require 'sketchup.rb'
          module TIG
            ### scales a select face about its center to a new area, in current uinits.
            def self.scale_face()
             model=Sketchup.active_model
             es=model.active_entities
             ss=model.selection
             fa=nil
             fa=ss[0] if ss[0]
             unless fa && fa.is_a?(Sketchup;;Face)
          	  UI.messagebox("Scale_Face;\n\nPreSelect ONE FACE !")
          	  return nil
             ar=fa.area
             mo=model.options["UnitsOptions"]
             p mo["LengthFormat"]
             case mo["LengthUnit"]
          	when 0
          	 units="in"
          	 if mo["LengthFormat"]==2 #Engineering trap ">>'
          	   units="ft"
          	   ar=ar/12.0/12.0
          	when 1
          	 units="ft"
          	 ar=ar/12.0/12.0
          	when 2
          	 units="mm"
          	 ar=ar*25.4*25.4
          	when 3
          	 units="cm"
          	 ar=ar*25.4*25.4/10/10
          	when 4
          	 units="m"
          	 ar=ar*25.4*25.4/1000/1000
          	else
          	 units="??"
             rs=inputbox(["New Area [sq "+units+"];        "], [ar], "Scale_Face")
             return nil unless rs
             na= rs[0]
             na= -na if na < 0
             unless na>0
          	  UI.beep
          	  return nil
             ro=Math.sqrt(na/ar)
             pt=fa.bounds.center
             tr=Geom;;Transformation.scaling(pt, ro)
             model.start_operation("Scale_Face")
          	 es.transform_entities(tr, fa.vertices)
             model.commit_operation
            UI.menu("Plugins").add_item("Scale_Face"){self.scale_face()} unless file_loaded?(__FILE__)
            file_loaded(__FILE__)
          Copy/paste code into a script in the Plugins folder named 'TIG-scale_face.rb', and restart Sketchup. Run it from the menu item or by typing TIG.scale_face in the Ruby Console...
          EDIT: Typo fixed in menu code !!!
          EDIT: Improved Unit/Fractional/Engineering handling - see 1st post in the thread for the .rb version.
            na = -na if na < 0
            Why not just use #abs ?
            na = na.abs
              @thomthom said:
              na = -na if na < 0
              na = na.abs
              No reason.
              I assume you meant na=results[0].abs as a one-step solution.
              I was just writing it on the fly and needed to trap for a negative or zero reply...
              Incidentally, I noted that you transformed the face while I did the face.vertices, is there any advantage in either way?
              Presumably transforming the face changes its vertices and what they are connected to anyway, and conversely transforming the vertices transforms the face and also whatever they are connected to also ?
                I'd expect that under the hood, when you feed entities to #transform_entities it collects the vertices - so [face] and face.vertices should have the exact same effect. I kind of liked face.vertices instead of wrapping the face in an array - feel it reads better as the brackets isn't so easy to see immediately.
                  Actually just face should work as well as [face] because the transformation is the first argument and you can then pass an array OR a series of arguments, so 'face' would be seen as the first one anyway ? ...
                    API-doh!
                      EarthMover
                      👍 You guys both rock! THANKS so much!
                        jorge2011
                        You see this plugin?
                        http://rubits.com/play.php?file=areascale
                          That's nice looking. The VCB is a nice way to control it. But I think $10 is too much for such a trivial script. 😕
                            EarthMover
                            TIG, having an issue with your script loading properly. I copied and pasted the code exactly into a notepad file and named it - TIG-scale_face.rb. Upon loading Sketchup, I get no errors, but none of my toolbars load. When I delete the script, all the toolbars load again.
                              EarthMover
                              Thom, excuse my ignorance, but how would I going about testing your code?
                                Sorry Adam, I typed it up and posted in a hurry. You'd put it in a .rb file and form the console invoke: TT_ScaleToArea.scale_face( Sketchup.active_model.selection[0], 4000 )
                                Didn't have the time to add UI.
                                  The code is now tested and working version... I edited the original ! http://forums.sketchucation.com/viewtopic.php?p=419936#p419936
                                  Stupid typo unless**.**file_loaded? instead of unless file_loaded?
                                  I added the UI as an afterthought and never tested it sorry!
                                    EarthMover
                                    Thanks TIG. It works as long as I am using a decimal unit type. With fractional units, it deletes everything in the model. Not sure why, just have to remember to switch the units before using the plugin. Thanks again. I'll update the first post with the rb file.
                                    Also it is still stating inches in the dialog even when the units are feet. No big deal though. Works for what I need. Thanks again! 👍 👍
                                      I'll adjust the code... I did type it on the fly...
                                        EarthMover
                                        If you have time. If not, no worries. I just figured I'd mention the issues in case anyone else needed to use the plugin.
                                          I've updated the .rb in your post and edited the post's text to match [hope you are OK with that 😉 ]
                                          It now handles all Unit-types/Fractional/Engineering etc properly.
                                          One oddity is that 'Engineering' displays on screen in 'feet', but the API unit-type [LengthUnit] is left in 'inches' [0] - unlike all other types where the 'LengthUnit' matches the displayed-unit.
                                          Anyway it now works for all combos... I hope 😕
                                            EarthMover
                                            Works great now. Thanks again.
                                            • 1 / 3
