    Sketchup & Vray Caustics
    renderpluginsextensions
    12 Posts 4 Posters 3.6k Views 4 Watching
    • Z
      zingis
      Greetings my friends!
      I am currently trying to create caustics for my swimming pool model. I followed tutorials such as:
      ---> http://www.youtube.com/watch?v=vbHdi5bEdlI (many special thanks to Fernado for the amazing work!)
      ----> http://triangleko.blogspot.com/2011/07/water-caustics-su-vray.html
      and settings such as:
      ---> http://www.scribd.com/doc/98795401/V-Ray-for-SketchUp-Pool-Water-Material-Settings-With-Caustics!
      All of the prementioned were extemely helpful and thank you people for doing them. However i still dont get caustics in my rendered image.
      Can anyone help or suggest what may I be doing wrong? Thank you people!!
      • eidam655E
        eidam655
        can you show us what you are getting?
        I'm using SketchUp 2017, V-Ray 3.4
        • Z
          zingis
          Hello eidam655 & friends,
          Sure i can!
          I am posting the image with NO caustics just to let you see what i am saying.
          I have also finally managed to get some caustics on another image but this was only temporary.
          I got them by luck!
          Sometimes i get caustics and sometimes not! The reason is that i have to
          place the water of the model (that i am experimenting with) in the area covered by the sun's photos in the model.
          However i am not quite sure how to achieve that everytime.
          I downloaded a plugin concerning the sun and the way it works in sketchup. It is called SKYview. But again i am having a hard time understanding how to get caustics or to be more specific, how to get photons from the sun to hit my water.
          Can someone help me please?
          Thank you people! I appreciate your help!
          Pool with no caustics
          • Z
            zingis
            hello eidam!
            ive uploaded a jpg. i would truly appreciated if you could have a look at it!
            Cheers!
            • V
              valerostudio
              Not sure how SkyView would affect VRay, if at all. Stupid question, but do you have caustics enabled in your options?
              • andybotA
                andybot
                I your sun settings in the "Sampling" settings, try changing your "photon radius" to something like 1500. Also, make sure your model is at your global origin. The radius sets how far away from the origin that the sun generates caustic photons.
                See this thread for more info: http://www.chaosgroup.com/forums/vbulletin/showthread.php?63088-does-caustic-work-in-1-49-00 (registration required)
                • Z
                  zingis
                  Hello valerostudio!
                  I was only trying to use skyview in order to understand the sun's paths and how it works around my model. Yes, my caustics are on! Thank you so much for your reply and i look forward to any extra help! Thanks!
                  • Z
                    zingis
                    Ok, i get what you are saying with the photons. I usually use a value of 500 but will have a try on 1500. My model is at my global origin (where the 3 axes meet right?). Your explanation has been really helpful and thank you, but i still have one question following with the images that i am about to upload. As far as the link is concerned i cannot view it. (I did register!)
                    Thank you andybot for your time & help!
                    • Z
                      zingis
                      Hello people,
                      Here i am once more. I am uploading 2 images. The first one shows the model of my pool, how it is located in sketchup in relation to the global origin, and the red dot indicates the view point.
                      The second image is different rendered scenes of my pool at different times. The 2nd image is the pool of the 1st image.
                      I am having a great trouble finding the sun's photons each time. As you can see at 8:00, 9:00, 10:00 i have no caustics. At 11:00, 12:00, 13:00, 14:00 i have some caustics with weird shapes. At 15:00 and 16:00 i have caustics!
                      • How can i locate the sun's photons each time without trying by luck?
                      • Why i am getting these weird shadows of straight lines? Isnt the sun circular in shape?
                      MANY THANK YOU TO ALL!!
                      • Z
                        zingis
                        The 2nd image
                        • andybotA
                          andybot
                          Sorry - I think you may have misread what I wrote. There is a different setting for photon "radius" that can increase the area where the sun is casting the caustic photons.
                          • eidam655E
                            eidam655
                            that second image looks helpful. have you tried checking whether your geolocation and timezone are consistent? for example i remember having problems with sunlight and shading when i placed a model somewhere in Central Europe, but my timezone was set to UTC -7.
