    Emissive and Reflective question
    renderpluginsextensions
    3 Posts 2 Posters 430 Views 2 Watching
    • A
      aconnoll
      This is probably easily solved but I can for the life of me get this to look correct. I'm wanting an emissive layer and reflective layer on the same material. Ive got the intensity set to 1.0 in a closed box with the physical camera off. Ive got fresnel property set in the reflective layer (set to 2.5). When I preview each layer in the material editor it looks correct, but when I test render as seen below, it doesn't look 3d at all and looks flat because there are no reflections.
      http://aconnoll.deviantart.com/
      • A
        aconnoll
        I should post more often to solve my own problems haha.. i just worked out it was the transparency setting of the BRDFLight layer. It was black and I changed it to a light grey.. seems to have made it look reasonable. Will play around with more settings to get it looking how I want..
        • V
          valerostudio
          Also, if you have 1.49.01 you can move the reflection layer above your emmissive layer and you will get a light bulb effect. 1.05.30 cannot do this but I dont know why the heck anyone would still be using that version.
