    How the hell i can do this???
    renderpluginsextensions
    6 Posts 3 Posters 834 Views 3 Watching
    • panixiaP Offline
      panixia
      i'm searching here and there to find a workaround to render moving objects in vray.
      the general opinion is that it is not possible, due to the fact vray doesn't support visible layer update in batch rendering.
      i read about this here: http://forums.sketchucation.com/viewtopic.php?f=323&t=33417
      then I found this video and it shows that SU-animate can do the job!
      i wonder how it is possible if the problem is on the vray side????
      anyone tried this? or maybe the new VFSU version (1.49.don'trememberexactlyi'venotvrayonthispc) solved the layer-visibility-update issue??
      i know twilight can do the job easily and i tried it a couple of time far ago and it worked, BUT the boss has vray on his machines at work and (most important) i don't like twilight at all, so I would like to stay with the VFSU solution as much as possible.
      can anyone help me please? i did't find any topic about SUanimate in this forum..
      grazie
      sorry for my bad english..
      • panixiaP Offline
        panixia
        just forget to link the video... 😳
        http://www.youtube.com/watch?v=n83qNwwFvZ0
        • andybotA Offline
          andybot
          um, perhaps he rendered each frame individually.
          • V Offline
            valerostudio
            As far as I know, Vray animation in SU doesnt support layer changes, so you would essentially have to go to each frame and render individually. I think Light Up supports animation???
            • panixiaP Offline
              panixia
              not suitable at all to my purposes 😒
              • panixiaP Offline
                panixia
                i hope layer change will be supported in the so waited new version.. πŸ˜’
