    Texture won't follow when moving object
    4 Posts 3 Posters 192 Views 3 Watching
      metaclay
      i got model from 3d warehouse :
      http://sketchup.google.com/3dwarehouse/details?mid=521d0ac00b5dad904e008e7476a1e2d5&prevstart=0
      i open this in sketchup 8 , problem is when try to scale the obj down , the texture won't follow. I check the texture map , the fixed pins are already off. To fix this, i go to texture/position menu , do nothing , just press enter to confirm, then now texture is following correctly while i move the face ..... but only for that face. How to do this for whole faces without manually do it one by one ? i'm confusing why this fixed pin didnt' work, is it a bug ? anyone got solution ? or anyone have any better workaround ?
      Thanx.
      Andi
      • massimoM Offline
        massimo Moderator
        Just group it (select all-->right click-->make group) and it will work.
          metaclay
          Perfect, i didn't think this can be solved that simple. thanx a lot Massimo. This is really helpfull.
            Aerilius
            This is usually caused when the texture has the default positioning (when using the paint bucket one does not define the texture positioning; it's only then defined when you or a plugin sets/edits the texture position).
