    Curious dialog box
    17 Posts 6 Posters 1.1k Views 6 Watching
      Looking close at the various send_action commands. Come across a couple that caught my attention, but I couldn't work out what they do:
      Haven't been able to make this do anything...
      Nor this. Wonder if it's part of Fix Problems check - or if it does something else. Might try it when I get a model that starts to create overlapping faces.
        tomot
        interesting!
        I wonder if there is a similar dialog box, that would allow a user to evaluate a simple division problem! instead of using the calculator?
        for example:
        total height 12' / no. of risers 18 = riser height 8 APPLY
        my plugins
        tomot
        • Dan RathbunD Offline
          Dan Rathbun
          We've discussed this. Someone (I think Fredo6,) made an Arithmetic plugin I believe.
          Here's quick and dirty inputbox:
          def query_for_riser()
            value = ""
            title = "Riser"
            begin
              input = UI.inputbox(['input riser (or calc)  '],[value],title)
              return nil unless input
              riser = eval(input[0]).to_l
            rescue
              value = input[0]
              title = "Riser (Try again)"
              retry
          end # def
          Type in "18.feet / 18" (without quotes)
          I'm not here much anymore.
            Dan Rathbun
            Ok I found the link:
            [Code] Parsing arithmetic formulas (Fredo6)
              Dan Rathbun
              Sketchup.send_action 21476 # PC only
              is the equiv. of:
              Sketchup.send_action "fixNonPlanarFaces:" # cross-platform
              And is defined on a utility menu (which is not implemented in the release,) as "Fix Non Planar Faces".
              This is separate from "Validity Check" id 21124 (which doesn't have a cross-platform string that I know of... or I just don't know what it is.)
              The 21124 is what happens when you click the "Fix Problems" button on the "Statistics" panel of the "Model Info" dialog.
                Aerilius
                  @aerilius said:
                  [attachment=0:1x1tajul]<!-- ia0 -->252.png<!-- ia0 -->[/attachment:1x1tajul]
                  Where did you find that?
                    Aerilius
                    It's defined in the exe (contains interesting old lumber). I didn't find a send_action code yet.
                      I thought...
                      20008 Macro
                      or
                      21082 Test Macros
                      but neither do anything except return true ?
                        Dan Rathbun
                        It could be just something that the MSVC++ application wizard adds to a new project, or it's in the default project template, etc.
                        Ask the SketchUppers ??
                          You extracted it from the EXE?
                            Dan Rathbun
                            Yes TT it is a resource in the exe file. I myself have also seen it. They are ALOT of dialog designs in there, and some have likely been orphaned, forgotten about etc.
                            You dont need to actually extract them, you can view any of them with the resource viewer/editor in MSVS.
                              Aerilius
                              Another interesting secret menu:
                              Note: the " %(#000000)[BugSplat Test]" shows a submenu which lists action codes 21560–21571. And 21910 screws... up!
                                Dan Rathbun
                                Which is no longer secret. 😒
                                Yea.. there is so much stuff in there, many on the SketchUp staff don't know about some of it. I actually had to inform one of the team members of those test "Splat!" send actions... to test a certain bug.
                                • Chris FullmerC Offline
                                  The Macro box that someone posted - SketchUp used to have a macro recorder in it. I think that was the interface for that tool.
                                  All my Plugins I've written
                                    Dan Rathbun
                                    @chris fullmer said:
                                    .... SketchUp used to have a macro recorder in it.
                                    That must have been back in the days before they integrated Ruby as a scripting engine ?
                                      Yeah it was back before version 4 I think. It recorded the mouse position on the screen and mouse clicks. So if you re-positioned your SU window, the whole macro broke!
