    Curious dialog box
    17 Posts 6 Posters 1.1k Views 6 Watching
    • Dan RathbunD
      Dan Rathbun
      @thomthom said:
      Nor this. Wonder if it's part of Fix Problems check - or if it does something else. Might try it when I get a model that starts to create overlapping faces.
      Sketchup.send_action 21476 # PC only
      is the equiv. of:
      Sketchup.send_action "fixNonPlanarFaces:" # cross-platform
      And is defined on a utility menu (which is not implemented in the release,) as "Fix Non Planar Faces".
      This is separate from "Validity Check" id 21124 (which doesn't have a cross-platform string that I know of... or I just don't know what it is.)
      The 21124 is what happens when you click the "Fix Problems" button on the "Statistics" panel of the "Model Info" dialog.
      I'm not here much anymore.
        Aerilius
          @aerilius said:
          [attachment=0:1x1tajul]<!-- ia0 -->252.png<!-- ia0 -->[/attachment:1x1tajul]
          Where did you find that?
            Aerilius
            It's defined in the exe (contains interesting old lumber). I didn't find a send_action code yet.
              I thought...
              20008 Macro
              or
              21082 Test Macros
              but neither do anything except return true ?
              • Dan RathbunD
                Dan Rathbun
                It could be just something that the MSVC++ application wizard adds to a new project, or it's in the default project template, etc.
                Ask the SketchUppers ??
                  You extracted it from the EXE?
                  • Dan RathbunD
                    Dan Rathbun
                    Yes TT it is a resource in the exe file. I myself have also seen it. They are ALOT of dialog designs in there, and some have likely been orphaned, forgotten about etc.
                    You dont need to actually extract them, you can view any of them with the resource viewer/editor in MSVS.
                      Aerilius
                      Another interesting secret menu:
                      Note: the " %(#000000)[BugSplat Test]" shows a submenu which lists action codes 21560–21571. And 21910 screws... up!
                      • Dan RathbunD
                        Dan Rathbun
                        Which is no longer secret. 😒
                        Yea.. there is so much stuff in there, many on the SketchUp staff don't know about some of it. I actually had to inform one of the team members of those test "Splat!" send actions... to test a certain bug.
                        • Chris FullmerC
                          The Macro box that someone posted - SketchUp used to have a macro recorder in it. I think that was the interface for that tool.
                          • Dan RathbunD
                            Dan Rathbun
                            @chris fullmer said:
                            .... SketchUp used to have a macro recorder in it.
                            That must have been back in the days before they integrated Ruby as a scripting engine ?
                            • Chris FullmerC
                              Yeah it was back before version 4 I think. It recorded the mouse position on the screen and mouse clicks. So if you re-positioned your SU window, the whole macro broke!
