    Curious dialog box
    17 Posts 6 Posters 1.2k Views 6 Watching
    • T
      tomot
      interesting!
      I wonder if there is a similar dialog box, that would allow a user to evaluate a simple division problem! instead of using the calculator?
      for example:
      total height 12' / no. of risers 18 = riser height 8 APPLY
      my plugins
      tomot
      • Dan RathbunD
        Dan Rathbun
        We've discussed this. Someone (I think Fredo6,) made an Arithmetic plugin I believe.
        Here's quick and dirty inputbox:
        def query_for_riser()
          value = ""
          title = "Riser"
          begin
            input = UI.inputbox(['input riser (or calc)  '],[value],title)
            return nil unless input
            riser = eval(input[0]).to_l
          rescue
            value = input[0]
            title = "Riser (Try again)"
            retry
        end # def
        Type in "18.feet / 18" (without quotes)
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          Ok I found the link:
          [Code] Parsing arithmetic formulas (Fredo6)
          • Dan RathbunD
            Dan Rathbun
            @thomthom said:
            Nor this. Wonder if it's part of Fix Problems check - or if it does something else. Might try it when I get a model that starts to create overlapping faces.
            Sketchup.send_action 21476 # PC only
            is the equiv. of:
            Sketchup.send_action "fixNonPlanarFaces:" # cross-platform
            And is defined on a utility menu (which is not implemented in the release,) as "Fix Non Planar Faces".
            This is separate from "Validity Check" id 21124 (which doesn't have a cross-platform string that I know of... or I just don't know what it is.)
            The 21124 is what happens when you click the "Fix Problems" button on the "Statistics" panel of the "Model Info" dialog.
              Aerilius
                @aerilius said:
                [attachment=0:1x1tajul]<!-- ia0 -->252.png<!-- ia0 -->[/attachment:1x1tajul]
                Where did you find that?
                  Aerilius
                  It's defined in the exe (contains interesting old lumber). I didn't find a send_action code yet.
                    I thought...
                    20008 Macro
                    or
                    21082 Test Macros
                    but neither do anything except return true ?
                    • Dan RathbunD
                      Dan Rathbun
                      It could be just something that the MSVC++ application wizard adds to a new project, or it's in the default project template, etc.
                      Ask the SketchUppers ??
                        You extracted it from the EXE?
                        • Dan RathbunD
                          Dan Rathbun
                          Yes TT it is a resource in the exe file. I myself have also seen it. They are ALOT of dialog designs in there, and some have likely been orphaned, forgotten about etc.
                          You dont need to actually extract them, you can view any of them with the resource viewer/editor in MSVS.
                            Aerilius
                            Another interesting secret menu:
                            Note: the " %(#000000)[BugSplat Test]" shows a submenu which lists action codes 21560–21571. And 21910 screws... up!
                            • Dan RathbunD
                              Dan Rathbun
                              Which is no longer secret. πŸ˜’
                              Yea.. there is so much stuff in there, many on the SketchUp staff don't know about some of it. I actually had to inform one of the team members of those test "Splat!" send actions... to test a certain bug.
                              • Chris FullmerC
                                The Macro box that someone posted - SketchUp used to have a macro recorder in it. I think that was the interface for that tool.
                                • Dan RathbunD
                                  Dan Rathbun
                                  @chris fullmer said:
                                  .... SketchUp used to have a macro recorder in it.
                                  That must have been back in the days before they integrated Ruby as a scripting engine ?
                                  • Chris FullmerC
                                    Yeah it was back before version 4 I think. It recorded the mouse position on the screen and mouse clicks. So if you re-positioned your SU window, the whole macro broke!
